Where is the Cooling Fan Relay Switch Located
Results 1 to 10 of 10
Thread: Where is the Cooling Fan Relay Switch Located
    Mar 2006
    1
    I have a 1998 Plymouth Grand Voyager and my cooling fans are not coming on. I have been told that this is most likely due to the cooling fan relay switch. I cannot find where this switch is located.
    Nov 2003
    936
    There was a recall associated with this. It is on the radiator support on the driver side. Call a dealer I believe it's a freebie.
    Larry
    Mar 2006
    32
    Let us know
    I have the same problem, let me know what you find out, and I will do likewise.
    Thanks,
    Chetzki
    Mar 2006
    32
    Called the dealer and they said it is not a recall item. Curious to know what danderson finds out. I have an inherent mistrust of dealerships.
    I haven't found the relay yet. I'll get it up on ramps and take another look.
    Chet
    Dec 2005
    Toronto, Ontario, Canada
    363
    1
    If you crawl on your back looking up just behind the front fascia on the rail below the radiator it is a flat thin wafer held onto the support with one or two 7mm self tapping screws. There was a recall on this. Call another dealer. Its failure can cause fast overheating and engine damage.
    2015 Jeep Summit Diesel- Brilliant Black, Tan Leather
    Past Mopars:
    2004 Town & Country Limited AWD Brilliant Black w/Tow Package, NAV and Sat Radio, ATE slotted rotors w/ceramic pads
    1999 Jeep Cherokee Sport
    1996 Plymouth Gnd Voy LE
    1994 Dodge Gnd Caravan SE
    1989 New Yorker 5th Ave
    1984 Plymouth Reliant
    1979 Plymouth Caravelle T bar Roof
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
    1955 Windsor Deluxe 4dr
    Mar 2006
    32
    Thanks. i chased the wires, took out the air filter housing and it's right there easy to get to. Got the part at O'Reilly's for $43 and installed it. Haven't had a chance yet to see if this will get the fans running again, but I suspect it will.
    Thanks again!
    Chetzki
    Nov 2005
    119
    1
    Recall Item
    Agree with everything said thus far. My 96 was covered under a recall for this, and they fixed it for free. I believe that you can punch in your make, model, and year at www.alldata.com to list all TSB's and recalls for your vehicle. Good luck!
    1988 Chrysler LeBaron Convertible, 2.2L Turbo (original owner)
    1996 Town & Country LXi Van, 3.8L
    1989 Beretta GT 2.8L V6 (original owner)
    2009 Honda Accord EX 2.4L I4 (original owner)
    Mar 2006
    32
    I replaced the relay for about $45 and everything works now. My Chrysler dealer insisted it was not a recall item so I did it myself. I went to alldata.com but they wanted money to get the level of detail I needed to find out if it was a recall item.
    Thanks All!
    Chetzki
    Oct 2003
    Ontario, Canada
    1,361
    You should be able to locate any outstanding recalls here, using your VIN number:
    CHRYSLER - Recall or Customer Satisfaction Notification Information
    Some 3rd generation vans did have a recall pertaining to the fan relay.
    Side note: I thought there were two fan relays in those vans?
    2014 Ram 4x4 Quad Sport, 5.7L Hemi 8-Spd, Flame Red
    2010 Journey R/T AWD, 3.5L , Stone White
    2007 Grand Caravan SXT, 3.8L 4-spd, Inferno Red, -SOLD-
    2001 Dodge Dakota Club Sport , 3.9L 4-spd , Flame Red -SOLD-
    Mar 2006
    32
    I went to the site and requested by email recalls issued prior to 1999. Very helpful.
    The relay I replaced has wires going to both motors for my fans and both are running.
    Thank ya!
    Chet
  1. cooling fan relay 1 control circuit
    By tdr73112 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-21-2011, 09:57 AM
  2. Where is nbs relay located voyager 1998!!
    By fidde74 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-22-2010, 07:38 PM
  3. where is the engine serial number located
    By mitogt in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-25-2009, 03:35 PM
  4. Where is the door adjar sensor/switch on the rear hatch located
    By jrprich in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-22-2009, 09:47 PM
  5. starter relay switch 92 Dodge Caravan
    By sugarbexar in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-14-2009, 09:44 PM
