PCV Valve location on '03 3.8L
Results 1 to 10 of 11
Thread: PCV Valve location on '03 3.8L
    Jan 2006
    Davison, MI
    77
    Hey, need some help! I just got a replacement PCV valve in the mail (note: the PCV valve for the 2003 3.8L was not available at Autozone or Advance auto parts--had to order online for like $15--pricey but hard to find)... and I can't find where the heck it goes!
    Can anyone tell me where this pesky thing goes? 37,000 miles and I should definitely replace it.
    Meet my 3.6L Fleet!
    Wife's: 2013 Chrysler Town and Country Limited (3.6L/62TE)
    Mine: 2011 Dodge Grand Caravan Crew (3.6L/62TE)
    My formers:
    2012 Chrysler Town and Country Limited (3.6L/62TE)
    2008 Chrysler Town & Country Limited ('08-'12) (4.0L/62TE)
    2008 Dodge Grand Caravan SXT ('09-'12)(4.0L/62TE)
    2003 Chrysler T&C Limited AWD ('04-'09) (3.8L/41AE)
    2001 Dodge Grand Caravan ES ('01-'04) (3.8L/41TE)
    1992 Plymouth Grand Voyager LE ('97-'01) (3.3L/A604)
    Dec 2004
    Virginia
    4,029
    It's behind the throttle body. You can see a rubber tube coming out of the top of it. It looks like it's hard to change. You find it easier to get at if you remove the black wiper cowl.
    BTW mine was just changed at almost 60,000 miles, and it made little difference. If it's not sticking, it can last and last. After you replace it, check the old one to see if it's still rattling--or if it's on a spring, to see if it's not sticking. if not, you should save it.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Jan 2005
    Fayetteville, NC
    9,436
    Ya, in general, PCV valves are not "wear" items like brakes or something like that. If it's sticking, it needs replacing, if it's not, it doesn't. The PCV valve in both of my vehicles is still the original one (one is 54k miles old and the other one over 150k miles old).
    But as Michael said, it's mounted on the REAR valve cover as the engine sits in the bay. Pretty much unvisible to the naked eye at first blush, but it's there.
    Dec 2005
    Toronto, Ontario, Canada
    363
    1
    I have an '04 and I was stumped too. Mine is located in the neck of the rear plastic valve cover. You have to reach to the back left as you face the engine and pull the hose off of the valve cover and the PCV valve is down inside. It is in large rubber grommet and you have to pull it out. It was dealer only.
    2015 Jeep Summit Diesel- Brilliant Black, Tan Leather
    Past Mopars:
    2004 Town & Country Limited AWD Brilliant Black w/Tow Package, NAV and Sat Radio, ATE slotted rotors w/ceramic pads
    1999 Jeep Cherokee Sport
    1996 Plymouth Gnd Voy LE
    1994 Dodge Gnd Caravan SE
    1989 New Yorker 5th Ave
    1984 Plymouth Reliant
    1979 Plymouth Caravelle T bar Roof
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
    1955 Windsor Deluxe 4dr
    Nov 2007
    Canada
    26
    Quote Originally Posted by oldchina View Post
    Hello Oldchina.
    New to the form and didn't want to post such a simple question and look silly.
    Have 2005- 3.3 engine and having a no luck in removing the PCV Valve.
    Question: Does the valve pull up and out? Screws in? Half rotation than pull out?
    The valve is loose, can rotate it in the grommet, but no way I can pull the valve out of the grommet without possible dammage.
    I just want to do an inspection 50,000KM on the old girl, but the dealer
    wants a small fortune for a replacement PCV valve it I blow it and damage mine.
    Apology for being a pain, but I need expert advice.
    Any suggestion appreciated. Vtech.
    Dec 2004
    Virginia
    4,029
    It twists out. Look it up on rockauto.com and you should be able to find a picture of it--that will give you an idea of how it comes out, then you should be able to get it out.
    but I would order one from Rockauto first, because you might break it. I think it cost less than $10 from there.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Dec 2005
    363
    1
    I was stumped too. my 3.8 was stuck tightly and you need to be forceful to get it out. The grommet gets kind of hard with the heat. You can spin the valve and rock it side to side and pull like **** then it just pops out. You may need to grab it with some kind of pliers though because its slippery with oil. I can't remember exactly though as I haven't changed it since 1 years ago.
    Past Mopars:
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
    Dec 2004
    Virginia
    4,029
    Did they change them from 03 to 04? The PCV valve I purchased is threaded on the bottom. it does not just "pop" out. Once you remove the hose from the top of it, you have to unscrew it.
    I have copied a picture of it from Rockauto, here:
    http://gallery.chryslerminivan.net/m...?g2_itemId=513
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Dec 2005
    363
    1
    They must have changed it, that doesn't look like mine at all.
    Past Mopars:
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
    Dec 2005
    363
    1
    I went to the Rock Auto site and it is definitely the wrong one for mine. When I got mine our Canadian Tire stores up here didn't offer one either. I had to go to the dealer. It may be the same as 2005. Rock doesn't show one at all for 2005.
    Past Mopars:
    1972 Imperial 4 dr
    1968 300 Convert.
    1968 Newport Custom
    1960 300F Coupe
    1960 300F Convert.
  1. PCV valve replacement - trouble with valve cover insert
    By bnut2000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2014, 07:35 AM
  2. Vent Valve Location on '03 T&C 3.3L
    By rmaxey in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-06-2010, 07:26 PM
  3. PCV Valve location on 3.8L 2005 T&C
    By khcnguyen in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-02-2008, 10:39 PM
  4. pcv valve location
    By voyager666 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-06-2007, 09:42 AM
  5. 3.8 Litre PCV Valve Location
    By skidad in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-24-2006, 06:09 PM
