ignition cylinder stuck
Results 1 to 10 of 20
Thread: ignition cylinder stuck
    Dec 2005
    Dublin, OH
    14
    Unhappy ignition cylinder stuck
    HELP! my 99GC ignition cylinder is stuck and trying with both master keys it won't turn. The steering wheel won't lock in both directions but I did hear the lock clicking mechanism when turning the steering wheel half round in both directions.
    Problem now is I can't even take the lock cylinder out to check as it needs to be in the "run" position to be removed. Shifter feels locked in "Park" position, any other components I can check?
    Dec 2005
    Dublin, OH
    14
    Update: Got the lock cylinder out after wiggling the key for 30mins, could not find a replacement cylinder in the local Advance Auto Parts or NAPA. Is this a dealer only part?
    Nov 2005
    119
    1
    I checked www.advanceautoparts.com, under SHOP ONLINE, and you're right, they don't have it for your vehicle. Unfortunately, you will probably have to buy one from the stealer. Good luck!
    Dublin, Ohio -- Home of Notre Dame stars Chris Quinn and Brady Quinn. Go Irish! Beat the Bucks in January!
    1988 Chrysler LeBaron Convertible, 2.2L Turbo (original owner)
    1996 Town & Country LXi Van, 3.8L
    1989 Beretta GT 2.8L V6 (original owner)
    2009 Honda Accord EX 2.4L I4 (original owner)
  5. #4
    Dec 2005
    Dublin, OH
    14
    Thanks, I went to NAPA and Advance and they both don't have the part. NAPA listed a lock cylinder up to 1997 and it looks different from the one I have.
  6. #5
    Feb 2004
    162
    I just had this same problem in my new-to-me 2000 Jeep Cherokee with 116,000 miles. I put my 1996 Yoyager key in there by mistake and it wouldn't work with the correct key afterwards. I thought perhaps some of the tumblers got pushed into an area that they had never been and the springs wouldn't release them.
    I sprayed the cylinder with WD-40 and let it sit over night. Next day I tapped with a wood dowel and a light hammer. Put the key in and voila....worked better than before. It was sometimes temperamental prior to getting stuck.
    A fair amount of dirt/grease came out with the WD-40 and tapping.
    Jay in MA
    2009 Honda Accord, 2.4 (Mobil1 5W-20)
    2009 Nissan Altima
    2000 Toyota Camry, 2.2
    1999 Toyota Camry, 2.2
    1995 Chevy S10 S.S., 4.3
    1985 John Deere 318 (Mobil1 10W-30)
  7. #6
    Dec 2005
    Dublin, OH
    14
    I had the lock cylinder replaced and re-keyed at a local locksmith, for $42 that's a ton a difference compared to the stealer quote of $140+
  8. #7
    Dec 2003
    Madison, WI
    2,665
    Country: Users Country Flag
    143
    Quote Originally Posted by trcar54
    Jay in MA
    Although this is good advice, I would caution against using WD-40 for this purpose. WD-40 can sit in the lock cylinder and collect MORE dirt and dust over time. Liquid graphite is generally a little better to use on lock cylinders, as it won't do this.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    -Current Wheels-
    1992 Plymouth Voyager- 6G72 3.0L, 31TH -- 235,000 miles -- "Bessie"
    2010 Ford Fusion S- Duratec 25 2.5L, 6F35 -- 56,000 miles -- "The Kid"
    -Former Wheels-
    2004 Dodge Stratus SE- EDZ 2.4L/41TE, 79,000 miles
    1999 Dodge Caravan- EGA 3.3L/41TE, 130,000 miles
    1996 Pontiac Grand Am- LD9 2.4L/4T40-E, 85,000 miles
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
  9. #8
    Feb 2004
    162
    lock cyclinderq
    I actually used the WD-40 on the advice of a locksmith. I wanted to use the WD-40 primarily as a medium to loosen up the tumblers if in fact they were stuck because of accumulated dirt. It seems that the WD-40 cleaned the tumblers and helped to carry some of the dirt outside the lock cyclinder.
    I don't think graphite would have had the same effect in my particular situation although I do think graphite as a followup would be a good idea if graphite is recommended for the application.
    Still working great.....
    Jay in MA
    2009 Nissan Altima
  10. #9
    Oct 2003
    Ontario, Canada
    1,366
    Powedered graphite is the best option for any lock. You don't want moisture in there.
    2011 Ram 4x4 Quad Sport, 5.7L Hemi 5-Spd, Flame Red, 60,000 kms
    2010 Journey R/T AWD, 3.5L , Stone White, 120,000 kms
    2007 Grand Caravan SXT, 3.8L 4-spd, Inferno Red, -SOLD-
    2001 Dodge Dakota Club Sport , 3.9L 4-spd , Flame Red -FOR SALE-
  11. #10
    Dec 2004
    Virginia
    4,031
    83
    The "WD" in WD-40 stands for Water Displacement.
    Michael
    Centreville, VA
    Currently driving:
    2005 Dodge Grand Caravan SXT, 99K mi.
    Former owner of:
    Other vehicles:
    2008 Lexus RX400h (Dark Gray), 65K mi; 2005 Hyundai Elantra GT (Blue), 65K mi
  1. Is my ignition key cylinder going?
    By pippo in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-09-2010, 04:59 PM
  2. ignition cylinder help please.
    By xitrum08 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-29-2009, 09:31 PM
  3. Ignition Cylinder Replacement?
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-11-2009, 09:46 AM
  4. Ignition cylinder replacement
    By RMan82 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-11-2007, 04:50 PM
  • You may not post replies
