Rusting Strut Tower 2000
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Rusting Strut Tower 2000
    Nov 2005
    Illinois
    6
    Need some help. I have a 2000 Grand Caravan which we purchased brand new and was babied from day one. Heated garage kept, wiped off every day, etc. Looks brand new. However, the left front strut tower is starting to rust through! My husband is furious. Chrysler has been of little or no help now that it is out of warranty. My husband thinks it's going to pop through soon. I heard there was a bulletin concerning this issue, but can't seem to get a copy of it. I'd also like to know if anyone has had this repaired and what they paid for it. I neither can afford or want to purchase a new van, so repair is our only option. I feel Chrysler should pay for this as it would seem to be some type of a defect in workmanship. Has anyone received any assistance from Chrysler? Please help. Thank you!
    Nov 2005
    Cleveland, OH
    3,880
    Country: Users Country Flag
    40
    Quote Originally Posted by busybarb
    So yay for worrying- your van is four years younger than mine and that's happening. How bad is the damage so far?
    1996 Chrysler Town & Country LX [My lovable Daily-Driver]
    2000 Chrysler Town & Country Limited [Yes, it's still around!]
    2000 Chrysler 300M [New kid on the block...]
    Nov 2005
    Illinois
    6
    Quote Originally Posted by Chrysler1924
    Has visable crack and rust. Like I said, my husband thinks it's going to pop through soon. We've heard some creaking noises of late, but maybe I'm just getting paranoid. My van only has 47,000 miles on it, so this is really frustrating to me.
  5. #4
    Mar 2005
    Dayton,Ohio
    193
    Sorry to hear about the rust problem. You need to have a professional bodyshop look at the problem. If it rust through you could have an unexpected change in the front end and the strut tower could let the strut shift and cause problems. I had this problem on a 98 T&C but sold it and do not know what was done to fix it. You may want to lower the temp in your heated garage. A friend of mine had a heated garage and had all kinds of rust problems on his cars. When you bring the car in from the cold moisture will build up on the inside of the metal panels and condense into the seams and cause corrosion to start. Even worse salt and road dirt caught in areas like the strut tower area will be more corrosive in the temp change bringing the cold car into a heated garage. This in it's self did not cause all the problems. Poor metal prep is usually the cause of the strut tower rust problem but the heat cool cycle does cause extra corrosion to start.
    2002 Town & Country LXi AWD Lt.Almond Pearl 3.8 V6
  6. #5
    Jul 2003
    High Ridge, Missouri
    4,806
    There is a TSB's on that:
    1999 Dodge Truck Grand Caravan FWD V6-201 3.3L VIN R SFI
    Vehicle Level Technical Service Bulletins All Technical Service Bulletins Suspension/Body - Strut Tower Corrosion
    Notes
    NUMBER: 23-044-02
    GROUP: Body
    DATE: Oct. 14, 2002
    SUBJECT:
    NS Strut Tower Corrosion
    OVERVIEW:
    This bulletin involves correcting a corrosion staining, surface corrosion, or corrosion perforation condition at the top of the strut tower/s.
    MODELS:
    1996 - 2000 NS Town&Country/Voyager/Caravan
    SYMPTOM/CONDITION:
    Cosmetic corrosion or perforation at upper strut tower/s usually between the strut and upper load path beam inner panel (inner fender).
    DIAGNOSIS:
    Inspect left and right strut towers for condition. If corrosion is present, perform one of the following repair procedures.
    NOTE: ANY UNDER HOOD LABELS REQUIRING REPLACEMENT DURING THESE REPAIRS SHOULD BE OBTAINED PRIOR TO BEGINNING REPAIRS.
    PARTS/MATERIALS REQUIRED
    EQUIPMENT REQUIRED
    REPAIR DESCRIPTION:
    Repair A - Cosmetic corrosion removal and the application of corrosion resistant materials and/or primers and topcoats.
    Repair B - Corrosion perforation removal and installation of 1 or 2 new cap/s and kit/s.
    NOTE: REPAIR PROCEDURES ARE OUTLINED IN THE INSTRUCTION SHEET INCLUDED IN THE PARTS KITS.
    POLICY:
    Reimbursable within the provisions of the warranty.
    © 2003 ALLDATA LLC. All rights reserved.
    Terms of Use
    If you want a copy of the tsb, e-mail me at : trdstr2000@sbcglobal.net
    Put STRUT TOWER CORR. in the subject line so I know it is not junk mail.
    Avatar: EconoVoyager Concept
  7. #6
    Jul 2005
    NJ
    1,562
    5
    I have a full text with part numbers, drop me a note if you want it.
  8. #7
    Dec 2004
    Toronto ON. CDN
    607
    26
    Quote Originally Posted by alvin
    Why not just post it? Just a question.
    KC.
    2012 VW Routan Highline w/ 3.6 L, 43 dealer km.
    2001 Dodge Grand Caravan ES w/3.3, 217,000 KM and still going!
  9. #8
    Nov 2005
    Illinois
    6
    Rusting Strut Tower
    You can reach me at busybarb@comcast.net I'd appreciate any info you can supply me. Thank you.
  10. #9
    Nov 2003
    936
    THere are 2 things helping to cause this. One is battery placement. The gasses from the battery cause sufuric acid to stay on top and 2 is your heated garage. BTW a heated garage is the WORST thing you can do to a vehicle. It's actually better to leave them outside. An unheated garage is next best but heated is definitely a no no.
    BTW I have the same issue on my 99 and I got a quote from a trusted body shop for $500. to weld in a new cap. Considering that the kit is $95.00 and the structural adhesive is about $135.00 I will have the body shop do it and know I didn't do something wrong. ;-)
    Larry
  11. #10
    Jul 2005
    NJ
    1,562
    5
    Quote Originally Posted by ESADORNED
    KC.
    I believe that would meet definition of "publishing" and be against the terms of my Infotraxx subscription. I hope this answers it.
  1. 2000 T&C 3.3 Strunt tower rusting
    By johnss56 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-06-2009, 08:54 AM
  2. rusting strut tower
    By leo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-03-2008, 12:56 PM
  3. Rusting Strut Tower--why won't Chrysler fix it?
    By peggidy in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-22-2008, 01:11 PM
  4. Strut tower rusting?
    By 3.0L V6 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-29-2005, 04:18 PM
  • You may not post replies
