How do I remove rear brake drum on 2000 Caravan?
Results 1 to 10 of 12
Thread: How do I remove rear brake drum on 2000 Caravan?
    Oct 2005
    1
    I promised my son I would replace the rear shoes on his 2000 Dodge Caravan. I removed the rubber plugs but cannot find a star wheel to back off on the shoes. Is a special tool needed? Is there a star wheel. Is there some place on the web I can find help? Any suggestions appreciated.
    Mar 2004
    U.K.
    56
    I had the same problem. I looked for the star adjuster but it's just not there. I decided to remove the whole assembly, service it and replace the shoes myself (it failed its M.O.T on the handbrake - parking brake to you guys) Once the wheel is off the drum/disc should come straight off providing you have released the cable tension beforehand. It was one of those easy jobs that turned in to a real nightmare. I could not remove the drum/disc assembly with anything! I finally gave in and took it to my local chrysler dealer to look at it for me. It turned out that part of the mechanism had seized/collapsed and prevented the drum from being removed ( could have siezed while driving and caused a nasty accident) Anyway, I'm 340 GBP out of pocket (they did both sides at the same time) but my handbrake now works and I feel a whole lot better now the car is safe.
    Jul 2005
    415
    The rear drum is held on with a nut, the wheel bearing is inside the drum.
    The studs are part of the drum.
    Remove nut, retainer pin, some big fat washers.
    Pull drum off spindle.
    Do not use a hammer if it is stuck.
    Push brake linings up with a flat tool if they are binding inside of drum diameter. Sometimes they wear a grove inside the drum which the linings get stuck in.
    Pull drum off and remember where the rubber seals go on the outer bearing in case they pop off when you get drum off.
    Getting the drum off is the hardest part, the rest is easy, including reassembling it.
    Do not "wash" the drum after you remove it, you do not want to get any water in bearing.
    Jul 2005
    NJ
    1,571
    6
    The above could be the case for earlier minivans but not gen. 3. The studs are pressed into the hub, and the drum has holes and sits between the wheel and the hub flange.
    The "star wheel" is really more like a knurled nut, and is at some depth away from the opening. A special tool, that looks like a large bent screwdriver, might be needed to turn it. But the important thing is to pull and hold the parking brake cable with locking pliers against the frame rail where it passes through. Simply releasing the brake doesn't create enough slack. I haven't yet had to do rear brakes but have spare shoes and some hardware that I can look at.
    Jul 2005
    415
    Jul 2005
    NJ
    1,571
    6
    That article says "Also, unless you work on drum brakes on a regular basis, you'll need a service manual specific to your car".
    Mar 2004
    U.K.
    56
    The handbrake on the uk models has a self adjusting ratchet which has to be released, otherwise when you install the new shoes you will not be able to get the drum/rotor assembly back on. I think the uk models differ from the U.S. models in quite a few ways.
    Jul 2005
    NJ
    1,571
    6
    The US-Canada parking brake is not a "hand" brake, but does have a self-adjusting ratchet and that's what needs to be released.
    Oct 2003
    Ontario, Canada
    1,361
    It might be helpful if members would specify the region of the world they are from. As mentioned, it influences what recommendations should be made. Not all vans are created the same.
    To add your location using the user profile / control panel, look here: User CP
    It will be shown in the title bar of your posts from that point.
    2014 Ram 4x4 Quad Sport, 5.7L Hemi 8-Spd, Flame Red
    2010 Journey R/T AWD, 3.5L , Stone White
    2007 Grand Caravan SXT, 3.8L 4-spd, Inferno Red, -SOLD-
    2001 Dodge Dakota Club Sport , 3.9L 4-spd , Flame Red -SOLD-
    Nov 2003
    936
    THey are basically the same except the brake here operates on a pedal and yours on a lever. Otherwise they are the same. The rear drums are very hard to remove but I have never had to "release" anything on any of the units I've ever worked on. First you need to break the drum loose from the hub. A plastic dead blow mallet is useful here. Than you need to get the drum over the ridge of dirt and rust. Keep working it and rotating it WILL come off.
    Larry
  1. Drum Brake rear adjuster lever
    By raj49 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-27-2009, 04:37 PM
  2. Rear Drum Brakes 2000 Grand Voyager 150K
    By Armadillo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-19-2009, 01:14 AM
  3. 02 rear brake drum drags\catches
    By jimsi in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-13-2007, 10:30 PM
  4. Rear Drum Brake Noise
    By BrooklynBridger in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-04-2006, 09:49 PM
  5. REAR DRUM removal-2000 mini-van
    By woodman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-18-2006, 08:12 AM
