Daytime Running Lights, NOT Equipped???
Results 1 to 10 of 11
Thread: Daytime Running Lights, NOT Equipped???
    Oct 2012
    Central Florida
    19
    I thought my 2012 T&C Touring would have had DRL's as standard equipment. I was driving in front of the wife the other day and noticed there was no DRL's. I went home and checked the vehicle settings and could not find an option to turn on or off. I just looked at the owners manual on-line and it states Daytime Running Lights (if equipped)??? I assumed that kind of feature would be standard now a days. Especially on this level of vehicle. All of my vehicles since 2005 have had them.
    Anyway, does anybody know if there is any programming the dealer can install to give me DRL's? Help is greatly appreciated.
    2013 Town&Country Touring L, Maximum Steel, 430N, Premium & Convenience Packages.
    1999 HD Ultra Classic, Luxury Blue Pearl over Silver.
    2013 HD Roadking FLH-P, Dark Peace Ofc Blue.
    Dec 2010
    The Hammer
    216
    This was discussed in another post that dealt with being able to change the van's settings with a computer, patch cord and certain software. I did a quick search but could not find the thread.
    As I recall, one of the settings is "country" and if you set the country code to Canada the daytime running lights are activated. I seem to recall that you could also control what lights were on when the daytime running lights were on. I'll try a bit more to find that thread.
    You may be able to get your dealer to emigrate your van to Canada so that you can have DRLs
    2015 Dodge Grand Caravan Crew Plus in Deep Cherry Red
    with Safety Sphere and Trailer Tow Packages
    2001 Mazda Miata SE in British Racing Green #1834 of 3000 made
    1.8L with a 6 speed manual transmission
    Jan 2008
    Nova Scotia, Canada
    16,494
    Take a look in your fuse box for the fuse that controls the lights. See if there is an extra slot beside it, and if there is, try that. Sometimes a fuse just has to be moved over to change a function, but I think that applies to something like the electrical outlets. Otherwise it's a different relay or reprogramming at the Chrysler Dealership.
    I think it has to be reprogrammed because of different laws in US / Canada.
    Sep 2012
    S.E. Texas
    35
    In this thread ChryslerCares says DRLs are only standard in Canadian market vehicles. I decided to add my own.
    Here's a link to the amazon page. They are blindingly bright to the point that they tap into the parking light circuit to dim them at night so you don't blind oncoming vehicles at night. This picture doesn't portray how truly bright they are. Took me maybe an hour at most to install.
    Jan 2008
    Nova Scotia, Canada
    16,494
    Looks like they made it more difficult as of 2008. Apparently it's possible but not well known or understood. Take a look here: http://www.justanswer.com/dodge/2uch...8-caravan.html
    Your van doesn't have a BCM! The TIPM controls the lighting, and there is not a different part for Canada or US markets. These are the same vans until they get put on the truck to their destination. From the service manual for your van:
    The TIPM must be programmed appropriately for this feature to be enabled. Once enabled, anytime the TIPM receives electronic messages over the CAN data bus from the PCM indicating the engine is running and from the EMIC indicating the status of the headlamp switch exterior lighting input is OFF and that the parking brake is released, the TIPM provides a pulse width modulated voltage output to the proper headlamp bulb filaments through the right and left high beam feed circuits to produce illumination at a reduced intensity.
    Read more: 2008 caravan: that to have daytime running lights..drl..tool - JustAnswer http://www.justanswer.com/dodge/2uch...#ixzz2B1Ly035u
    If your vehicle comes back to Canada and is registered in Canada, it will have to have the DRLs enabled as part of the process. So, Canadian Dealerships would know the answer for sure.
    Jun 2012
    17
    bravada how did you wire them?
    Bravada how did you wire them. I am going to add these from amazon and wire them to come on when the car is on. i am going to put them under the lights and will post pictures when i do them. I am not sure how to wire them up.
    Quote Originally Posted by bravada View Post
    Jan 2011
    5,260
    Quote Originally Posted by Jeepman View Post
    Hasn't been that easy for a while
    Sep 2012
    S.E. Texas
    35
    Quote Originally Posted by msmpugs98 View Post
    The Philips DayLight 8 has a relay box that goes to the positive and negative of the battery and automatically turns the lights on and off based on voltage.
    Oct 2012
    Central Florida
    19
    Good info all, Thanks.
    Apr 2013
    2
    Can anyone describe in more detail on how the wiring works? I am planning on getting the same set as described here, but may install them in the slot above the fog lights.
