Changed fuel pump, now having trouble filling tank
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: Changed fuel pump, now having trouble filling tank
  1. #21
    Jan 2013
    1,086
    It takes only one badluck and you are dead. Just my two cents.
  3. #22
    Sep 2007
    86
    Thanks
    0
    I am facing a fuel pump replacement on my 2005 T&C as I have been experiencing a small leak directly at the pump itself. Have the typical odor issue after parking in the garage...no mileage loss or puddling under the car...yet. I'm actually waiting for a break in the summer heat here in FL to do the job...LOL. After doing much research on the procedure to r&r the pump, one manual made a big issue about removing the flex hose between the fill tube and the plastic tank only at the filler neck end and leave the flex tube attached to the tank. Not sure why but just curious if you did this or not. I'm guessing its either due to some type of inlet valve to the tank or just staying away from the plastic tank itself due to its ability to be easily damaged.
  4. #23
    Apr 2009
    Empire State
    3,814
    Quote Originally Posted by jee34 View Post
    ... static electricity.Gas tanks are made of plastic,..
    All of the plastic gas tanks I've seen so far are made from "anti-static" additive infused plastic and most are grounded to the chassis...
    that said, CO2 or NO2 is a much safer gas to mix with fuel. One would obviously want to empty the tank before any attempt to pressurize the fuel.
    relevant vehicle: '05 -=C=- T&C Ltd @~135K
  5. Remove Advertisements
  6. #24
    Jan 2014
    Ash Flat, AR
    1,843
    Scratching a plastic hair comb on your head makes static electricity.Gas tanks are made of plastic,forcing air into the thank is like compressing fuel+air mixture...
    Anything is possible
    2006 Dodge Caravan SXT, 3.3, 91,000 mi, 4/17/2014
    2003 Dodge Grand Caravan SE, 3.3 Flex Fuel, 231K mi, 8/7/13
    1994 Dodge Cummins 3500 Dually, 212K mi
    1988 Dodge Mini Ram Van Aztec Conversion, 203K mi
    1986 Ply Voyager
    1970 Dodge C900 diesel truck tractor
  7. #25
    Feb 2017
    2
    Thanks
    0
    changed fuel pump now having trouble filling tank
    I have exactly the same problem and have done many of the checks that you have.......did you ever find the problem?
  8. #26
    Feb 2017
    2
    Thanks
    0
    I have exactly the same problem........where did you end up? I am about to re drop the tank but i would really like to have a better idea as to what i need to do!
