oil change light reset question
Results 1 to 7 of 7
Thread: oil change light reset question
    May 2012
    36
    Hey guys...2011 caravan and the manual states to reset the oil change light turn key to the "on" position and fully press down on the gas pedal three times...now my question. Isn't this also a great way to flood your engine? Or is that a thing of the past? Advice needed! Thanks a lot guys.
    Jul 2011
    Fishersville, Va.
    29
    Thing of the past. My 2008 and 2011 Caravan reset the same way.
    Grumpaw
    Apr 2007
    Minnesota
    4,206
    The injectors don't fire when you are doing that, so it won't flood.
    Nov 2010
    516
    Only would flood a carbureted engine... hard to find one of them there carburetors these days!
    '11 Grand Caravan Crew 3.6 74k
    '13 Escape SEL 2.0T AWD 34k
    http://www.fuelly.com/driver/smgussey/
    2011+ tow package info: http://forum.chryslerminivan.net/showthread.php/23413
    May 2006
    292
    6
    Although if you hold the pedal all the way down and turn the key, the car will not start. I do this after I change to oil for a few seconds to get oil in the oil pump.
    Present:
    2016 Dodge Grand Caravan SE Plus
    2010 Chrysler Town & Country Touring 4.0
    2004 Chrysler 300M
    Past:
    2011 Dodge Grand Caravan Express (Blown Transmission 7-15, 122K)
    2006 Dodge Caravan SXT (sold 6-11)
    2005 Dodge Grand Caravan SXT (traded 4-10)
    1994 Plymouth Grand Voyager Conversion Van (R.I.P)
  8. The Following User Says Thank You to Concorde300M For This Useful Post:
    gsmagnum(09-07-2012)
  9. #6
    Apr 2009
    Empire State
    3,789
    Quote Originally Posted by morzy41 View Post
    Electronic Throttle Control (aka drive by wire) = no throttle cable, all the gas pedal does is send a signal to the computer (PCM) that it is being depressed...
  10. The Following User Says Thank You to atoman For This Useful Post:
    ChryslerCares(09-10-2012)
  11. #7
    Dec 2010
    The Hammer
    215
    Quote Originally Posted by atoman View Post
    Does the PCM provide some medication for its depression
    2015 Dodge Grand Caravan Crew Plus in Deep Cherry Red
    with Safety Sphere and Trailer Tow Packages
    2001 Mazda Miata SE in British Racing Green #1834 of 3000 made
    1.8L with a 6 speed manual transmission
