antifreeze leak Grand Caravan
Results 1 to 10 of 15
Thread: antifreeze leak Grand Caravan
    Aug 2012
    6
    Have a slow drip of coolant on my 1999 grand caravan on the passenger side.
    Its dripping onto the plastic shielding in the upper corner in front of the the wheel about a foot in from the side.
    I cant see anything topside of leakage near the belts or anywhere inside the engine bay by flashlight.
    have any ideas?
    Trying to determine how much this is going to cost me cause im pretty mechanically stupid
    Jul 2008
    Niles Il.
    10,101
    It is likely from the water pump dripping onto the splash shield. I would take a look at it, they have a weep hole on the bottom.
    '69 GTO drop top
    Aug 2012
    6
    but isn't the water pump further inside the engine bay next to the timing chain?
    This is right up in the front left corner almost under the pressure overflow tank but i don't see anything indicating a leak from there.
    Apr 2007
    SoCal
    5,328
    Is the drip green? Is the coolant level low? Could it be the windshield washer tank leaking?
    Oct 2003
    Mt. Sinai N.Y.
    268
    15
    The coolant blows around from the moving belts. I had a leak in the same area, it was the pump. Have someone put it on the lift
    Aug 2009
    Vancouver B.C.Canada
    408
    Get it on a lift as Philip suggests. Shops will usually take a look on your behalf for free. Water pump is most likely culprit. Maybe a small slit in the bypass hose a little lower. Hopefully your ride is a 3.3 or 3.8 liter.
    1996 Plymouth Grand Voyager 3.8L LE FWD
    Everything's Working - No Drippin' or Burnin'
    440,000 Kilometers - 275,000 Miles
    1989 Voyager 2.5 liter Turbo-Automatic (deceased in a freeway spill 2006)
    1987 Voyager 2.2 liter 5-Speed Manual (Burgundy Red - very clean)
    Jul 2009
    917
    8
    I had a leak that sounded similar, and it was not the pump. It was the radiator leaking.
    Leon
    '97 Town & Country LXi
    Aug 2012
    6
    Yes it is a 3.3 and i know its the antifreeze as my temps get hot and i have to add about a gallon of water/fluid to top it off every time.
    After i top it off it takes a few days to get low again.
    Thanks for all of the assistance hopefully it wont get too costly to replace the pump i don't know how much that would cost me ill have to call around some.
    Money is tight at the moment ill have to wait a week or so till i can get it into a shop to get it looked at.
    Think ill be ok for a week limping it along on only short trips to the store no long drives ?
    Aug 2012
    6
    Quote Originally Posted by lyonkster View Post
    I hope its not the radiator that will set me back a bit more than merely needing to swap out the pump or a hose.
    Nov 2008
    Milwaukee
    124
    Just changed out my waterpump on my '00 Grand Caravan last night (3.8L), it's only $20-25 for the pump, and easy to DIY. Bolts are 10mm for pump body, 13mm for pulley, and a 15mm box wrench to loosen the tensioner to remove the belt. There are small holes on the pulley to stick a screwdriver thru (to keep it from spinning) to take the pulley bolts off. Couple of hours max to do it. It sounds like you already got the antifreeze so go at it.
    -Andrew
    2010 Chrysler T&C Touring 3.8L V6 Black
    1991 Chevy Astro 5.7L V8 5-speed Maroon
    1983 Yamaha Venture 1200 V4 White
    1981 Yamaha 650XJ Maxim I4 Black/Green
    2000 Dodge GC 3.8L V6 Blue - GONE
