Auto lock activation
Results 1 to 7 of 7
Thread: Auto lock activation
    Apr 2012
    15
    Unhappy Auto lock activation
    I need help how to activate the autolock at 15 mph.
    1993 Chrysler T&C. Tried the on & off 4-times, it is not happening.
    May 2012
    Centralia, WA
    54
    Is there a procedure in the manual? Do you have an OEM Factory Service manual? Those are my only two thoughts....I don't have it on my Caravan, since it's not a high end version by any means.
    Another thought, turn the locks on, then remove the battery cable, let sit for 30 seconds, then put the cable back on....best guesses here. I don't have children, so I don't worry about it.
    Richard
    92 Dodge Caravan - 3.0 Autopuke
    5 other cars in my collection...believe me I have to many projects
    Nov 2011
    Slany, Czech Republic
    162
    it is on and off 4 times and then you have to lock your car using power lock button on your doors. then it should work.
    this guide imho works only if you have overhead console with trip computer. if you don't, you have to go to repairshop and have it activated using diagnostics but is should work since you have TC.
    edit: http://www.ehow.com/how_4423279_set-...h-voyager.html
    Chryslers and Skodas I have or had in the past
    My current daily-driver is: Chrysler Grand Voyager 3.8 LE 1995 AWD
    Mine oldtimer
    Apr 2012
    15
    I have tried the on & off procedure several times with no luck. I do have a digital dash with overhead trip computer. The service manual does not give the how to do. It does however mention the use of DRB-II.
    Dec 2004
    Virginia
    4,029
    Quote Originally Posted by voyager1993 View Post
    It is in the owner's manual, it's not just on & off, it's a combination of on & off along with hitting the power lock button on the driver's door. Apologies if you already know this. It's not clear by your reference that you are doing anything more than just cycling the key on and off. You don't need a service manual, just an owner's manual.
    I don't remember the exact procedure from the 2nd gen, but IIRC it is essentially unchanged between that vehicle and the 4th generation. The biggest difference might be that in the 2nd gen, the horn beeps, or the locks lock to tell you you are done, and on the 4th generation, there is a chime. The first three steps for the 4th gen are as follows:
    1. Close all doors and place the key in the ignition switch.
    2. Cycle the ignition switch ON/OFF four times ending in the OFF position. (do not start the engine)
    3. Within 10 seconds of the final cycle, press the interior driver’s door lock switch to the LOCK position.
    After that, as I mentioned above, there is some kind of indicator that you were successful (either the lock actuates or the horn beeps, I can't remember which). On the 4th gen it's a chime, but I don't remember it being the chime on my '95.
    Hope this helps.
    Michael
    Centreville, VA
    Currently driving: 2015 Jeep Cherokee Trailhawk
    Former owner of:
    2005 Dodge Grand Caravan SXT, 129K mi.; 2008 Nissan Quest, (2008-2010, 25K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi);
    Nov 2011
    162
    i told him about hitting the button already... and I believe it doesnt indicate at all on 2nd gen
    Mine oldtimer
    Apr 2012
    15
    Thanks mmahamm,
    I tried the procedure several times very carefully. I do not hear any confirmation sound from horn and/or chime, and the auto lock not being activated. I just hate to spend $$$$ for DRB-II or similar scan tools.
