Driver's power window won't go up or down
Results 1 to 10 of 10
Thread: Driver's power window won't go up or down
    May 2009
    Virginia
    487
    236
    What are the typical causes? My vehicle has sat for a long time so this doesn't surprise me.
    98 Caravan SE AWD, 159K, New Rear Cylinder Head, Rotella T6 5W-40 w/Motorcraft FL-400s, Magnetic Oil Drain Plug, Dayco Serpentine Belt Kit, Heavy Duty radiator with twin internal transmission coolers, Dayco Upper and Lower Radiator hoses, Blue Silicone secondary radiator hoses, Peak Global Lifetime Coolant w/ Distilled water, Blue Silicone valve cover hose, Fram Air Hog Air Filter, 130 Amp Alternator w/ 1.7" Pulley to fix no charge at idle issue, 4 gauge power/ground to alternator, Jasper Tranny w/ Redline C+ Fluid and Dorman drain plug pan, Redline fluids in PTU/Diff, Curt Tow Receiver Kit, Unknown Aftermarket wheels with wheel locks & Cooper 225/60/16 CS4 tires, Napa Blue Poly Sway Bar End Links, Ceramic Front and Rear Advance Auto Pads and Rotors, Tinted Windows, Galant VR-4 AWD sticker on tailgate, No Rust, NSF Certified TYC Headlamps with GE Nighthawk NHX 9007 Xenon bulbs, Koolatron P-20 Cooler, Headrest TVs
    Jul 2009
    Pickering, ON
    2,281
    35
    Motor died, switch went bad, cables binding, a few possibilities.
    sent from my Univac using Assembler.
    http://forum.chryslerminivan.net/image.php?type=sigpic&userid=13818&dateline=124855  5576
    ____________________________
    08 Grand Caravan SXT Silver 3.3L
    07 Impala SS, 323 cubic inches divided into 8 mighty pots.
    May 2009
    Virginia
    487
    236
    I figured that much. Any of these more common than the others?
    Quote Originally Posted by madbrad View Post
    Feb 2008
    Central British Columbia
    801
    The motor going out is the most common, you can try tapping the motor housing with a solid object while pressing the switch to see if it starts moving, if it does, most likely the brushes are worn out.
    I have read on here that some people have taken the motor apart and bent the terminals to make better contact to the rotor, this may be only a temporary fix.
    2003 Caravan SXT 3.3L / 1997 Grand Voyager SE 3.0L / 1991 Plymouth Voyager 3.0L / 1989 Plymouth Voyager 2.5L / 1988 Caravan 3.0L / 1984 Caravan 5 Speed Stick
  7. The Following User Says Thank You to hwystar For This Useful Post:
    4_cars(06-01-2012)
  8. #5
    Jul 2009
    Pickering, ON
    2,281
    35
    Yeah me too, first thing I would do is open up the door panel and get to the motor, Isolate it and maybe even tak eit out if it is seperable from the regulator, and on a workbench put 12V to it to see if it works.
    I have not looked in detail at mine or any chrysler van windo motor setup so I don't know if it's seperable. You can leave it in place and unplug it and bring 12V to it with wires from the battery, and while you're there test to see if the other half of that plug has 12V when you hit the switch.
  9. The Following User Says Thank You to madbrad For This Useful Post:
    4_cars(06-01-2012)
  10. #6
    Jan 2008
    Nova Scotia, Canada
    16,539
    Since the van has been sitting for awhile, perhaps the window glass is stuck to its tracks. Can you move the window glass some to loosen it? The motor has overload protection and will disconnect quickly under high enough resistance.
    Otherwise take a look at this Post: http://forum.chryslerminivan.net/sho...430#post231430
    Good luck.
  11. The Following User Says Thank You to Jeepman For This Useful Post:
    4_cars(06-01-2012)
  12. #7
    Jul 2008
    Niles Il.
    10,101
    Hold the button with the door open and slam the door while still holding it. If it starts working, replace the regulator.
    '69 GTO drop top
  13. The Following User Says Thank You to andyg For This Useful Post:
    4_cars(06-02-2012)
  14. #8
    May 2009
    Virginia
    487
    236
    Pushed down on the window while pressing the down button. Has worked ok since! Thanks again all.
  15. #9
    Jul 2008
    Niles Il.
    10,101
    You should plan on replacing the regulator assembly soon before it stops working and won't come back to life at all. That makes replacing the regulator more difficult if it is stuck in the wrong spot.
    '69 GTO drop top
  16. #10
    Jan 2008
    Nova Scotia, Canada
    16,539
    Sounds like the glass was stuck in its tracks from sitting so long. Likely needs a little silicone lubricant on the tracks. It won't hurt to remove the panel and lubricate the cable, pulleys and gears.
    Mine gets lubricated via the rustproofing I spray in the door cavity (up through the drain holes, using a wand). Products like Fluid Film, Rust Check, Rust Block and Rust Cure Formula 3000 are great lubricants as well as rust inhibitors.
