Dash speakers
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Dash speakers
    Feb 2011
    Bronx, NY
    166
    Dash speakers
    How does one access them?
    Searched the web. Came up with nothing.
    Also any way to test if its the speaker
    Or a bad wiring somewhere else?
    Thanx all
    Vehicle - 01 T&C 3.3L about 80,000 miles
    Apr 2012
    Kansas
    200
    Always a good idea to let us know what the problem is. For example: My stereo only works from the rear speakers and no matter what I set the fade or balance on, no sound from the front. Or, I get only static from my left front speaker, what could the problem be. Also helps if you tell us what stereo you have. Is it the OEM or has it been changed out?
    To my understanding, replacing the dash speakers is quite a chore as removal of the dash is required. As for testing the speakers, I would use the speaker leads behind the radio to test each speaker. Obviously it could be the radio, wiring or speaker. Has anything happened to the front speakers? I was working on a car once where the vehicle stopped short, and the passenger holding a large Coke spilled the entire Coke on the dash into the speaker. The speaker continually buzzed after that and the owner just cut the wire to that speaker as replacement was too difficult.
    2005 Town & Country Limited
    Oct 2003
    Niagara Ontario
    825
    The dash speakers are easy to get at, you need to pull off the window pillar trim panels first then carefully pry up the front dash panel with a putty knife. Are you sure your van came with dash speakers? Niether of my vans had them from the factory. Easy to retrofit in as the wiring is already there. Just look at a wiring diagram to be sure of the positive and negative polarity. 5-1/4" is the size that fits.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
  5. The Following User Says Thank You to Hankster For This Useful Post:
    Dumpy(05-21-2012)
  6. Remove Advertisements
  7. #4
    Feb 2011
    Bronx, NY
    166
    Thanx for the quick responses.
    Sorry I didn't elaborate more.
    Anyways:
    I do have dash speakers. The one on the right works perfectly fine base and everything.
    The one on drivers side sounds like only a tweeter in there. Sometimes it just hisses(no sound).
    I have the oem cassette radio.
    Ive tested it by dimming sound from back to front. Left to right, etc.
    Seems to me the speakers are 6x9"
    I will test it the way you suggested.
    Thanx.
  8. #5
    Mar 2009
    Tobyhanna, PA
    98
    1
    Quote Originally Posted by Hankster View Post
    Hank
    There's wiring up there already? If thats the case then i'm getting speakers for that spot soon. I need someone to guarantee this....
    My Vans:
    2007 Dodge Grand Caravan SXT 3.8L V6 in Magnesium Pearl with ~ 126,000 miles
    1999 Plymouth Grand Voyager SE 3.3L V6 in Champagne Pearl with ~ 144,000 miles
    2003 Dodge Grand Caravan SE 3.3L V6 in Dark Garnet Red Pearl with ~204,000 miles - Junked/R.I.P.
  9. #6
    Oct 2003
    Niagara Ontario
    825
    The wiring will be there, I simply cut the factory plugs off and crimp on terminals. I am doing this upgrade on my 2007 this weekend, and did my 2005 about 3 - 4 years ago when I first got that van. I will report back as to the polarity of the wiring after I check the wiring diagram in my manual. I was supprised to find out that my 2007 didn't come from the factory with 6 speakers even though it is an SXT model.
    Hank
    90 Shadow long gone
  10. #7
    Oct 2003
    Niagara Ontario
    825
    I just installed the speakers into my 2007, the wiring was already there like I expected. The plugs were simply taped back onto the wiring harness.The whole job took less than 1/2 hour to complete. The wire with the yellow strip is the positive and goes to the positive connection on the speaker. The A pillar panels and dash panel popped out by simply pulling them out carefully with my fingers. No tools needed. Just a stubby phillips screwdriver to turn the speaker screws.
    Hank
    90 Shadow long gone
  11. The Following 3 Users Say Thank You to Hankster For This Useful Post:
    06DGC(06-22-2013), BrianS(05-19-2012), Dumpy(05-21-2012)
  12. #8
    Mar 2009
    Tobyhanna, PA
    98
    1
    Maybe it's because you have an SXT and I have an SE.
    My Vans:
  13. #9
    Apr 2009
    Ontario Canada
    32
    On the SXT, are the dash speakers 6 X 9 ?
    I find there is too much base for my liking.
    04 GC SXT 3.8L 112,kL (mine)
    02 Pontiac AZTEK 3.4L 206,kL (hers)
    06 Mazda 3 2.3L 130,kL (hers /acquired summer 2015)
  14. #10
    Apr 2012
    472
    On Crutchfield.com they list the dash speakers as a 5 1/4," for my 2005 SXT. I'd like to get this speaker when I get a job: http://www.crutchfield.com/p_091IC13...er-reviews-tab
    1995 Grand Caravan 3.8L - wrecked in hwy crash after a night of insomnia
    1999 Grand Caravan Sport - died of strut rust, kept it for 6 years - 30,000 miles
    2005 Grand Caravan SXT - 3.8L loaded with dvd, tow package, traction control, & load leveling, bought @ 126,764 mi for $5900
    1999 Honda Civic HX M/T - gets me 51.2 mpg hwy @ 70 mph in lean burn 5th gear [3000 rpm]. 26 mpg in horrendous Chicago
    city driving.
