Last week while driving home, my van just cut off & won't restart. After getting it towed home I ran the codes and got the following:
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0123 Throttle Position Sensor Circuit High Voltage
P0442 Evaporative Emission (EVAP) System Small Leak Detected (often this is a loose or bad gas cap!)
P0455 Evaporative Emission (EVAP) System Leak Detected
P1193 - Inlet Air Temp. Circuit High
P1598 - A/C Pressure Sensor Volts Too High
P1684 - Battery Disconnected Within Last 50 Starts
P0509 – Idle air control valve
I called the local Dodge dealership and they are no help, they want up to 160 just to see what it might be. Only thing he told me to try was disconnect the battery for a while and re-run the codes. I did and when reconnected it only gave 1684, 0123, 0509. And it still wont start. I replaced the battery today and now have all the codes again with out the van starting. ps: I still have not found any bad wires.
Please help. thanks.
