2011 Chrysler Town & Country Limited Transmission Problems
Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 10 of 173
Thread: 2011 Chrysler Town & Country Limited Transmission Problems
    Mar 2006
    Rockford, IL
    45
    Is anyone else experiencing transmission problems while in economy mode shifting from 1st to 2nd gear. Transmission clunks into 2nd gear. Brought to dealer once and they replaced valve body. Just recently brought back to the dealer on Tuesday and they are tearing the transmission apart again. 2nd day with loaner car.
    2011 Chrysler Town & Country Limited, Trailer tow pkg, Blackberry pearl
    2002 Chrysler Town & Country Limited, 185K
    Nov 2011
    Northwest Arkansas
    229
    It's my understanding that the economy mode instructs the trans to shift from 1st to 3rd gear. I quit using the econo mode in my 2011 because I didn't like the driveability sacrifice resulting from econo mode in stop and go traffic.
    Strange that the dealer is tearing into the transmission for that.
    Jan 2011
    5,293
    Turn the eco mode off. If its fine, try and get the reflash that supposedly fixes it.
    Apr 2007
    Minnesota
    4,206
    It seems like you have a really aggressive service department.
    The last recall flash on ours seems to have fixed the "Econ issue". We have actually been leaving it in Econ much of the time since the recall flash was performed.
    I hope they aren't doing a bunch of "repairs" for nothing.
    Jan 2011
    5,293
    Quote Originally Posted by gsmagnum View Post
    Good to hear.
    I'll ask about it when ours goes in for the next oil change
    Apr 2012
    6
    Hi guys, I'm having exact the same symptoms when on ECON mode on my 2012 TC. Brought it to the dealership and mentioned about a reflash and info I've gathered from forums like this one. What I'm getting though is the reverse of what has been discussed here.
    According to them, if I feel the tug/clunk in non-econ mode, then there is no problem and no need for a re-flash. Snce it's happening only on econ mode, it's "normal" just need to drive slowly. i'm really getting frustrated here Seems like I have to "drive like my grand mother" to avoid the clunking (sorry no dis-respect to seniors, just using a phrase I heard so many times).
    UN4GTBL, kindly post your experience, whether yours got a re-flash or not. If you did, how is the drive when on ECON mode.
    Thanks!
    Apr 2012
    6
    Sorry, was it jaag82899 who was going to try to get a re-flash on the next oil change? Anyways, please do post an update afterwards.
    Apr 2007
    Minnesota
    4,206
    They told me there were no transmission flashes for mine when it was in. It did have the recall flash done. It has shifted without the 1-3 clunk since then though.
    If you have a heavy foot, Econ mode is pretty worthless. Having it off will improve your shifting.
    I like having it on to keep the converter locked up and in top gear at slower speeds.
    Jan 2011
    5,293
    Quote Originally Posted by rtracing View Post
    Thanks!
    In non-econ mode it should be smooth...
    But yeah, you can't keep it in econ mode and drive around like a mad man, its not meant for that.
    I'm going to see if there is a re-flash for ours on the next oil change.
    Exactly.
    Nov 2010
    516
    As mentioned Econ mode will be clunky, mainly due to the 1 to 3 skip-shift. It has to cut power to the engine for a longer time while the transmission shifts. Also, the torque converter locks up much more quickly, making feel like it's shifting rough.
    The shifting problems that I had were cured with the recall flash --- mainly slamming into drive gear after backing up, so much so that you could see the front tires lurch ahead when shifting from reverse to drive. (yes, I come to a complete stop before shifting) --- the recall flash fixed that, so I'm assuming there was an updated computer program for the transmission as well.
    My favorite use for Econ mode is driving on the highway - it stops it from "hunting" for gears or downshifting on every little hill. I lose a few mph, but to me that's better than the shifting.
    '11 Grand Caravan Crew 3.6 74k
    '13 Escape SEL 2.0T AWD 34k
    http://www.fuelly.com/driver/smgussey/
    2011+ tow package info: http://forum.chryslerminivan.net/showthread.php/23413
