Hitch Install - 2011 Dodge Grand Caravan
Results 1 to 5 of 5
Thread: Hitch Install - 2011 Dodge Grand Caravan
    Aug 2011
    Moncton, NB, Canada
    7
    Hi Everyone
    I have obtained a hitch from a 2010 Dodge Caravan, I know the hitch will bolt up no problem, but what I want to know is will I have to cut my bumper..?
    Also, has anyone done their own install? I have no problem doing this kind or work, and from what I have found out all that has to be done is drop the exhaust (1 clamp I guess) and then bolt it up with existing bolts. I have a torque wrench, so doing it to proper specs (if I can find them) shouldnt be an issue.
    My van does not have a towing package, but I only plan on using the hitch for a bike rack right now, and possibly a small utility trailer at times.
    So, if anyone knows about having to cut the bumper or not, and also if anyone knows install specs for hitches, that would be perfect!
    Oh, its a U-HAUL brand hitch.
    -Daniel
    2011 Grand Caravan SXT - Mango Tango
    2006 Yamaha BWS 50cc Scooter
    Nov 2010
    516
    Some info here: http://forum.chryslerminivan.net/sho...w-Bars-Hitches
    and here: http://forum.chryslerminivan.net/sho...235#post225235
    I believe it is only the Mopar hitch that requires cutting the bumper, the others hang below it. You may have to do some trimming, though as the '10 vs. '11 rear bumper cover is different - I would imagine that the mounting points underneath would be the same. It may just bolt right up without any trouble.
    '11 Grand Caravan Crew 3.6 74k
    '13 Escape SEL 2.0T AWD 34k
    http://www.fuelly.com/driver/smgussey/
    2011+ tow package info: http://forum.chryslerminivan.net/showthread.php/23413
    Mar 2012
    19
    Installed last weekend on my 2012 a hidden hitch with the Curt Wiring harness. Easiest bolt on ever. Since mine has no rear air con I didn't even have to worry about the Freon line that runs near the hitch install area on those equipped vans. One word of advise from my experience is when you install the wiring harness black box inside the drivers side rear light cavity well, go low because they only give you one piece of 3m double sided tape to stick the box on. I was about 6 inches to high and when I route the other wire to the the other light I was short. I ruined the double sided tape by ripping it off and had to run to the hardware store for more.
    Tow Hitch Install video 2009 Dodge Caravan
    http://www.youtube.com/watch?v=52cSxDniBPE
    Tow Hitch Wiring Harness Install video 2010 Dodge Caravan
    http://www.youtube.com/watch?v=2FiqhQhXxrM
    Aug 2011
    Moncton, NB, Canada
    7
    Thanks for the replies! Here is the instructions for install of my hitch, which is the same for 2010 & 2011
    http://www.uhaul.com/pubshandler.ash...B52yzuvX/B8Fcw
    Mar 2012
    Portland, Oregon
    30
    TheTrader: Bad link
    2010 Chrysler Routan...er, VW Town & Country...er, I mean Lancia, uhm...
    2006 Ducati Sport Classic 2002 VW Passat 1.8t; 1995 VW Jetta; 1976 VW Riviera Bus; 1972 VW Squareback
