97 Chrysler Town & Country Gas Gauge Problems
Results 1 to 9 of 9
Thread: 97 Chrysler Town & Country Gas Gauge Problems
    Jun 2005
    2
    My 97 T&C LXI has a gas gauge problem, the gauge will drift from full tank to empty and set off the bell under the dash (ding, ding ding etc.). When the tank is full no problems, but when itís filled just under full the dinging starts. Is this a computer problem, a sending unit problem? Any help is much appreciated.
    Oct 2003
    Ontario, Canada
    1,361
    My '97 Caravan used to do that...fuel guage would go nuts when it reached 3/4full.
    I'm sure there is a tsb for it, and the fix was quite simple if I remember.
    I'll see what I can dig up.... in the meantime maybe someone else has the service bulletin handy.
    2014 Ram 4x4 Quad Sport, 5.7L Hemi 8-Spd, Flame Red
    2010 Journey R/T AWD, 3.5L , Stone White
    2007 Grand Caravan SXT, 3.8L 4-spd, Inferno Red, -SOLD-
    2001 Dodge Dakota Club Sport , 3.9L 4-spd , Flame Red -SOLD-
    Jun 2005
    2
    Jul 2003
    High Ridge, Missouri
    4,760
    Here is one tip you can check out:
    http://forum.chryslerminivan.net/showthread.php?t=859
    Avatar: EconoVoyager Concept
    Apr 2005
    18
    Had the same problem a few years ago. Replaced the sending unit, which requires dropping the fuel tank and removing the fuel pump. Decided to go ahead and replace the fuel pump since a new one comes with the sending unit already attached. You can get the sending unit separate from the dealer, but it was about half the cost of the Carter (OEM) fuel pump obtained from the local parts store. By the way, went ahead and replaced the fuel filter since it also requires lowering the tank also. Bottom line is that the sending unit was the problem. Good luck.
    Oct 2003
    Ontario, Canada
    1,361
    Rich, do you have a searchable index of TSBs? I am near positive that there was one related to this fuel guage problem. May even be specific to '97 model years. I know at the time, I did not have to replace any parts to fix it. Unfortunately I cleaned off my PC a while ago...and tossed the archives of TSB I had on file for my old van.
    Jul 2003
    4,760
    I have checked all of them that I have and can find nothing for the 97 year. The 2001-2002 model had some TSB's but nothing I can find on the older vans.
    Jul 2005
    Iowa
    8
    need to replace the sending unit the armature brushs are probably woren out that is what sends the message to the fuel gauge in your instument cluster panel. its definetly your sending unit.
    Jul 2003
    4,760
  1. 2005 Town & Country LX Electrical Problems
    By Apathetic in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-28-2015, 10:51 PM
  2. Random Starting Problems in 2000 Town and Country
    By ronrule in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-05-2010, 10:10 PM
  3. 1994 Town And Country Fuel Gauge Problem (Digital)
    By Lord Plecostomus in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 09-25-2009, 09:54 PM
  4. 2002 town & country Problems
    By ao3dave in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-04-2005, 03:47 PM
