98 plymouth voyager 2.4L transmission problem
Results 1 to 2 of 2
Thread: 98 plymouth voyager 2.4L transmission problem
    Mar 2012
    2
    dont no if this is the right place to post this.
    iv got a 98 voyager with a 2.4L 3speed trans changed the filter and fluid because it was not shifting right would chug and die at stop signs had to put it in 2nd to keep it from doing that. sometime when you take off its like it is in high gear. theres no code no check engine no ses. any ideas?
    Mar 2012
    2
    nobody has any ideas? on a 3speed transmission in a 98 voyager?
