<<Great site! ...I have a 1996 Caravan with a 3.0 V6 liter in it, it just turned 146000 miles and I have been having a few problems for about 500 miles..*1* It has been giving me a loud ticking sound (like a desiel engine) at speed, idle is has almost no sound..when i place my hand on top of the motor i can feel it "kicking" *2* it will stall at stop lights with the AC on (im in Florida, i needs my AC) *3* it has a bad oil leak, im thinking valuve cover gaskets on the back of the motor,,is there an easy way to change it ? *4* the horn, cruise and turn sigs stopped working, i understand there is a recall for this, before i get ripped off by the dealer. it there a time limit on the recall?????I really enjoyed this van but if its going to cost me an arm and a leg to fix her..ill have to go for something else. >>
Welcome Beachbummm
Hard to say with the first one without hearing it. Is your oil level low? Have you changed oil recently and are you using the correct viscosity (5w-30 or 10w-30)? Is your oil level TOO HIGH? This can do it also.
Stalling with a/c on and when stopped could mean a dirty throttle body. Take the rubber tube off from the air box and with the engine off, open the throttle with your hand and look down the throttle body. It is probably all black inside. It needs to be cleaned because it is blocking the little air that is supposed to get thru when the throttle plate is closed.
The valve covers on the 3.0 only have 2 fasterners holding them on. Try "snugging" the bolts down. If already tight, remove and replace the gaskets. Not a hard job, just a little time consuming. I would also check the PCV and hose to see if they are blocked up and causing an increase in pressure in the engine and helping to blow oil out the valve covers.
There is no time limit on a recall. Check with your dealer about having it fixed and make sure yours IS covered by the recall.
I hope this helps. Keep us informed on how it goes.
Avatar: EconoVoyager Concept
