2000 Caravan died and won't start back
Results 1 to 10 of 13
Thread: 2000 Caravan died and won't start back
    Jan 2012
    6
    Hi everyone. I have a 2000 caravan and was driving to work today and it suddenly died with no warning. There was no rough engine, no flashing lights, no ping ping ping. I tried to restart it and it turned over fine but to my ear it sounded like it was getting no fire. All the lights, radio etc work fine. An important detail, I have had a pretty badly leaking water pump for about 4-5 weeks and since the timing belt is somewhere near there is that a potential culprit? Thanks all for any suggestions.
    Jun 2011
    SE Michigan
    4,334
    If I read you right this a 2.4L? A leaking water pump could have knocked the timing belt out. See if the cams still turn when you crank it over.
    2013 TC Limited Black/Graystone Custom ordered 5/13
    Luxury non Stow & Go buckets, Tow and almost everything else. Lifetime Max Care warranty. Driven to 36 states so far.
    1994 Grand Caravan SE Sport, 3.3L, 350,000+ miles and counting. Original engine and trans. Bought it new and have driven it to 48 states. Now my daughters daily driver.
    Jan 2012
    6
    Thanks 1994. I hate to sound unknowledgable, even though it's true, but how can i tell if they are turning?
    Oct 2008
    2,469
    43
    When is the last time you changed the timing belt? You can take the oil cap off and see if you can see the valves move, if not there is an inspection cover somewhere, I believe. I had one of these.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jun 2009
    St. Cloud, MN
    1,667
    Which engine is it? Could be as simple as a bad crank sensor/wiring/connection, or as bad as a cracked flexplate. The 3.3 and 3.8 V6 have a timing chain, and I thought the 2.4 L4 did too? Also, if the engine got really hot it won't start, because the ECU prevents it to protect the engine. Had that happen to our van last summer when the cooling fans went out.
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
    Jan 2012
    6
    tc, I haven't ever changed the timing belt and its almost at the 150k mark. I'll try the oil cap method and see what i see.
    Ripper, the motor is the 4 cylinder. I'm fairly certain the motor didn't over heat because i faithfully fill the radiator before every trip. In my original post I said that while the motor was cranking it sounded as if there were no fire. Is it possible the distributor/coil has gone bad? Would that cause the engine to shut down while driving? Thanks to all of you!
    Feb 2008
    Central British Columbia
    796
    Sounds like it could be just the fuel pump quit working
    If you turn ON the ignition switch do you hear the fuel pump run for about 2 seconds?
    2003 Caravan SXT 3.3L / 1997 Grand Voyager SE 3.0L / 1991 Plymouth Voyager 3.0L / 1989 Plymouth Voyager 2.5L / 1988 Caravan 3.0L / 1984 Caravan 5 Speed Stick
    Jan 2012
    6
    hwy, I do hear the fuel pump priming when I turn the key. Sunday I'll be able to get in there and do a bunch of tests. Let everyone know then! Thanks!
    Jan 2012
    6
    Hello, everyone. I still can't start the minivan. Today i replaced the ignition coil and spark plugs plus the Auto Shut Down relay. Everything works great electrically but no start. Anybody have any idea if maybe the fuel pump is the culprit? When i turn the key on I hear a whirring sound for about 6 -7 seconds coming from behind the glove box. Would i hear the fuel pump there? Or is the timing belt still a likely source of the problem? I still can't find a way to see if the cams move. Thanks to everyone for the help!
    Feb 2004
    South Bend, IN
    982
    28
    destes, If the timing belt or chain(whatever engine you have) is off, you would mostly likely hear the engine cranking really fast and it would not sound anywhere near "normal" because there would be no compression. You do not seem to indicate such so I am thinking your timing chain/belt is fine.
    You really have a "good" problem. That is, the engine has quit altogether and is not intermittent. Those intermittent problems can be really hard to fix. So try these steps but only if you feel mechanically competent to do so.
    Isolate the issue between spark and fuel. To do this, get a can of starter fluid from the local auto store and spritz a couple of shots into the intake snout (where the air filter is) and give it a crank. Take precautions and realize that the starter fluid is highly flammable. So don't overdo it (and perform this outside) but don't be frozen with fear either. If the engine makes ANY attempt to fire, then you have a fuel delivery problem. If not, you may have a spark issue. That could be a sensor as someone mentioned. But first, try to isolate the cause.
    Remember to think "simple". It is SO easy to start imagining the worst sort of scenario and it is usually something rather simple.
    98 Town&Country LXI, 3.8L, 192k miles (sold)
