I have a 96 Plymouth Grand Voyager LE, with the 3.8L. For the last year there has been a vibration in the steering wheel from 100Km/h and up. (60 miles/hour) The vibration is slight at that speed, but increases with speed. At 140km/h there is so much vibration that it seems likely to vibrate right off the road. This problem seems much like a tire balance problem, as it is an up and down vibration, not a side to side. I had the tires balanced 3 times at 2 different places, and thought perhaps it was a harmonic wheel imbalance, but borrowed a friends rims and tires which were balanced on his caravan, and there was still vibration. So tires/rims have been eliminated. I got new tie rod outter ends last month, along with new struts up front, and shocks in the rear, and anti-sway bar bushings. The transmission isn't the cause because i had that blow appart in the mountains in february, and with the new rebuilt one, the vibration is still there. When popped into neutral at speed, the vibration doesn't go away either.
Has anyone had this problem, or know what it might be? Any help would be great!!
