Guages not working
Results 1 to 4 of 4
Thread: Guages not working
    Jun 2005
    1
    Unhappy Guages not working
    I have 96 Dodge Caravan. The Speedometer, Gas guage, Tach, and Temp. Guages quit working. I checked the fuse and they are OK. Eveything ekse seems to be working even the cruise control. Any suggestions?
    Jun 2004
    Michigan
    133
    Haven't done anything strange lately like jump starting the car, replacing the battery, take apart your instrument panel??
    I have had my IP apart before and your problem is either your IP is shot or you aren't getting voltage to the panel. There really isn't much you can do to repair the unit if it is broken that I am aware of, but you should be able to find out if you are getting power there with a multimeter.
    Do any of your dummy lights work??? What happens when you turn your key to ON? are all of the gagues dead??
    Good Luck
    Best Regards,
    David
    08 Chrysler T&C Touring
    96 Chrysler T&C
    Dec 2003
    Eau Claire, WI
    2,800
    This is probably either a BCM issue or a relay issue (as mentioned above). I had this issue on the 1992 once and I had luck with just resetting the BCM by unhooking the battery cable and killing power to it. Hopefully this will solve the problem, because if it doesn't, it could be an expensive fix.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
    Jun 2004
    rochester,ny
    763
    7
    dash
    Quote Originally Posted by stanthemanessner
    Open the hood and in the fuse and relay center just above the battery locate the IOD fuse usually near the top of the box and pull and reseat the fuse a couple of times . This will fix this a lot of times .
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    55000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    111000 miles
  1. 3.3 engine noise/guages
    By jwp1775 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-14-2010, 12:40 PM
  2. Some guages not working, check engine light on
    By jyeaman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-27-2009, 04:09 AM
  3. AC Guages
    By thanson in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-01-2009, 03:49 PM
  4. 91 Plymonth guages stop working!
    By honeybunz32 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-06-2008, 07:48 PM
  5. Guages non functional
    By dmonroe67@aol.com in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-20-2007, 10:20 AM
