Super Console Removal
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Super Console Removal
    Sep 2011
    24
    So this morning sitting at the Tim Hortons drive thru I sat some change on the Super Console sliding cover..........bad move, the money slid inside the console and every time I hit a bump I can hear the change rattle.
    I looked underneath and there is an LED light and another small hole. Anyone know how I can get inside to remove the money.
    It is not that I am cheap and want it back, I just hate rattles and squeaks!!
    The picture shows where it slid inside the Super Console.
    2011 Dodge Grand Caravan CREW Plus
    Jan 2011
    5,204
    Yeah i hear you on rattles and squeaks. Hopefully somebody can help you with this.
    Apr 2007
    San Diego
    5,171
    Quote Originally Posted by huntsvillian View Post
    It is not that I am cheap and want it back, I just hate rattles and squeaks!!Attachment 3969
    Thank you for making that clear. We don't associate with THOSE kind of people here...uh hu
    May 2008
    Issaquah WA
    1,000
    There is a access panel in that little cubby area, if you are on the drivers side go into the pass through cubby area it will be on your right also pull the drawer out will make it easier...
    2011 T&C Limited - Deep Cherry Pearl, Black Napa Leather, Sunroof, PWR 3rd Row,
    2005 Dodge Ram 3500 Cummins Turbo Diesel, 4x4 Quad Cab - Laramie - Fully Loaded with options. Edge EZ, Lots of LED Lighting.
    Sep 2011
    24
    I tried that, it only gave me access to underneath the cup holders and the rear compartment on the console. It looks like the only way is to try and remove the whole console.
    May 2008
    Issaquah WA
    1,000
    OK, there is two bolts on each side near the floor and a push pin rivet on each side under the hvac controls. Make sure that you unplug the power jack connectors...
    Mar 2012
    2
    Same problem
    Is there a way to remove the top of the super console instead of removing the whole console? There is a seam that follows along on each side of the console that meets up in the rear of the super console above the drawer.
    Mar 2012
    2
    I had the same problem with my 2011 Dodge Grand Caravan R/T but with a driver's license. There is a way to remove the top of the super console instead of removing the whole console. There is a seam that follows along on each side of the console that meets up in the rear of the super console right above the drawer. I was able to pry (lack of a better term) lightly enough to where the clips popped loose. I carefully worked my hands along the seems forward toward the front while gently lifting from from the rear. Once I worked it all the way forward there are 2 clips that are a little stubborn so I used a plastic knife to pop them loose. Be carefull as there are wires that are attached.
    It may not be the right method but I took great care not to break anything as my wife would never let me live it down.
    Nov 2012
    7
    I can confirm Bluedragn69_98's Method, My Wife lost her Debit Card the same way as OP. The Dodge Dealer wanted $900 to pull it apart. All I did was Pull out the Drawer, reach under and pull up firm but not hard and the entire top of the console came up, very easily actually. Found $0.45 and our Debit Card. No issues with re-installation, made sure wires did not get pinched. Started with Dash side and just snapped them back down.
    Total Time ~10 Minutes, 5 of which I stared at it prior to trying any dismantling.
  12. The Following 3 Users Say Thank You to fryguy503 For This Useful Post:
    Active8(12-15-2015), smgussey(11-10-2012), UN4GTBL(11-10-2012)
  13. #10
    Sep 2012
    Tehachapi, CA
    66
    Yup, that is the way I took apart my console to replace the little change drawer with a DVD player. Just pry up on it starting from the back.
    2011 Grand Caravan Crew (sold)
    2012 Honda Odyssey (needed the 8th seat) <-- Wife's current ride
    2011 Prius III (sold)
    1999 Suburban 2500 (sold)
    2002 Suburban 1400 <-- Trash hauler and 4x4 backup vehicle
    2011 Chevy Volt (RIP) Lost in flood October 2015
    2015 Chevy Volt <--- Current ride
