No Audio from my RB1
Results 1 to 10 of 19
Thread: No Audio from my RB1
    Aug 2011
    FL
    14
    Just bought a new to me T&C with every option available, but my RB1 produces no sound. Everything looks OK radio stations change navigation works sound bars go up/down, but nothing via the speakers. What could it be? I have checked a fuse that says central amp and visually it appears OK. Please tell me it's nothing serious
    Dec 2009
    MA
    284
    5
    As strange as it sounds, make sure you actually have speakers. Recently bought a PT cruiser for my wife, and it took me longer than I'd like to admit to figure out that the reason the radio wasn't working was someone had removed all the speakers when they traded it in!
    2011 Grand Caravan, 3.6, 144k miles
    1993 Chrysler Concorde, 3.3 150k miles
    1999 GMC Suburban k1500, 5.7, 179k miles
    2006 Pt Cruiser 2.4, 129k
    1987 Monte Carlo SS Aerocoupe 5.0, 76k
    1997 Firebird Convertible, 3.8, 53k
    1960 Corvair Sedan, 2.3, 87k
    Past Caravans:
    2005 Grand Caravan SXT, 3.8 247k miles, Sold
    2002 Grand Caravan SE, 3.3, 166k miles, Sold
    Apr 2009
    Empire State
    3,786
    first thing to check would be the presence and functionality of the 'NBS' relay in the IPM/PDC (under hood)...
    then you have a choice of pulling the radio or the dash speakers and checking them.. (if outputs on RB1 are good, check the amps on the speakers..)
  5. #4
    Aug 2011
    FL
    14
    So I checked under the hood and appears that I don't have NBS relay just an empty slot for it. I had placed fog light relay in it but no sound yet. Tried jumping pins 30 and 87 to no avail. What would be the next step? I can try pulling the RB1 too and look around but not sure what I would be looking for or metering what?
  6. #5
    Apr 2009
    Empire State
    3,786
    just so we're on the same page here what's your (van's) model year and 'trim level' (LX, touring, limited etc) - does it have the 8 speaker infinity system..
    since you don't know the history of the van it could be anything from replacement IPM (that was from a lower trim or not programmed correctly) to a retrofit head unit (it could have had something other than RB1 from the factory..)
    I'd say a good place to start would be to get a Chrysler spec sheet for the van and see what options it had from the start.. (esp. if it's a Touring or LX)
  7. #6
    Aug 2011
    FL
    14
    So I haven't pulled the VIN on it in fact not sure where to even do that, but the tailgate says it is Limited and I believe it since it has every option except sunroof. Options like leather and nav, dvd, parking sonar, curtain and knee airbags. In terms of speakers I can see two on the front doors, 2 on top of the dash then 4 in the rear (2 small tweeters) and that's all I could see this morning. Still not sure if it's infinity or what. Previous owner said that everything was working until a few days ago when the sound stopped while his wife was playing with navigation... Not sure if it's true but whatever. Also I could tell that NBS relay hasn't been in there for a while (maybe never) since the socket was a lot dustier/dirtier than any other socket on IPM, however when I put my multi meeter on the socket I could read +12 volts on pin 85 and 86 after the radio turned on. I have tried shorting 30 and 87 without any success. The 30A central amp fuse is good, but when measuring Amps I don't see any draw (with NBS bypassed or not).
    What speaker is the easiest to remove in order to tell if it's infinity system or not? Also my VIN is 2C8GP64L85R417301 in case anyone has access to the database.
  8. #7
    Apr 2009
    Empire State
    3,786
    every '05 limited I've ever seen had the RB1 and infinity from the factory...
    since the problem supposedly appeared after someone 'played' with the radio, you can try to pull the IOD fuse for a few minutes (10-15) and see if anything changes (aside from resetting the clock and possibly presets..)
    [that would be the easiest starting point..]
    if you get around to pulling the top dash trim, you will have access to the front speakers (they should have amps on them..if they're infinity)
  9. #8
    Aug 2011
    FL
    14
    So knowing that it's Limited and most likely infinity, then would you say it is rather strange that NBS relay is missing? Also is puling the top dash cover the easiest way to determine speaker type? And assuming they are infinity and relay is there and working, what is the next component to inspect (besides doing IDO fuse)? I have disconnected the battery few days ago for 30 minutes or so hoping it will bring the sound back, but will do it again just in case. Thanks for the help BTW.
  10. #9
    Apr 2009
    Empire State
    3,786
    missing NBS relay could be explained several ways - lowline 6 speaker audio (either a factory oversight or someone ordering the van that way, if it was possible or a repair shop work..) someone just pulled it out OR IPM was replaced at some point.. all are pure speculation
    FSM says to check ground and scan it with a DRBIII.. though I'd just pull the head unit from the console (2 screws for the HVAC faceplate and a few bolts for the radio) and check the outputs (you can check the output channels one at a time with an old pair of headphones...just be sure you don't short out the outputs)
    you can find the wiring diagrams on the dodge bodybuilder site..
    Quote Originally Posted by '05 FSM
    AUDIO SYSTEM DIAGNOSIS
    CONDITION
    POSSIBLE CAUSE
    CORRECTION
    NO AUDIO.
    1. FUSE INOPERATIVE.
    1. CHECK RADIO FUSES IN FUSE BLOCK MODULE.
    REPLACE FUSES, IF REQUIRED.
    2. RADIO CONNECTOR
    DAMAGED.
    2. CHECK FOR LOOSE OR CORRODED RADIO CONNECTOR.
    REPAIR, IF REQUIRED.
    3. WIRING DAMAGED.
    3. CHECK FOR BATTERY VOLTAGE AT RADIO CONNECTOR.
    REPAIR WIRING, IF REQUIRED.
    4. GROUND DAMAGED.
    4. CHECK FOR CONTINUITY BETWEEN RADIO CHASSIS AND
    A KNOWN GOOD GROUND. THERE SHOULD BE
    CONTINUITY. REPAIR GROUND, IF REQUIRED.
    5. RADIO
    INOPERATIVE.
    5. USING A SCAN TOOL, CHECK FOR TROUBLE CODES IN
    THE AUDIO SYSTEM.
    6. SPEAKERS
    INOPERATIVE
    6. REFER TO SPEAKER DIAGNOSIS.
  11. #10
    Aug 2011
    FL
    14
    So I pulled the head unit out last night just to look and everything was nice and clean and plugged in. Haven't checked anything yet since my multi-meeter probes were too thick to get in there, plus I didn't really know what wires were going to the speakers (I assume the smaller square connector). One other observation I had made was that the steering wheel push buttons (on the back of the wheel) are not working, or at least they apear to not work since no radio stations change nor volume adjusts. Also when I hit Aux/cd button it is not letting me to play from the changer. All other buttons work but aux/cd does nothing. However if I load DVD into the changer the back TV screen starts playing the movie so I know that the changer works but not allowing the radio to reed from it (or at least it looks that ways since I don't get track # or anything on the radio when Aux/CD button is pressed). Can those things be the cause of no sound or at least indicate something?
    2005 T&C Limited, Silver 94K
Tags for this Thread
