99 Town and Country Limited - Won't Start (on occasion)
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: 99 Town and Country Limited - Won't Start (on occasion)
    Jul 2011
    4
    This has happened twice in about a month. Go out to start up the old van, turn the key, gauges are dead, won't turn over, but everything else works (fan, lights, radio, etc). Let it sit for a couple of days the first time then it fired right up. Happened again last weekend, couldn't get it started and had it towed to the shop. Guy calls me today and says it fired right up, no error codes, and doesn't know what the problem is.
    Any ideas?
    Jul 2011
    4
    Also should add I hear the relays clicking in the fuse box....
    Jun 2009
    St. Cloud, MN
    1,667
    Next time it does it, bang on the top of the dash (over the instrument cluster) and see if it starts. There is a soldered connection behind the instrument cluster near the top of it, that cracks and causes problems like yours. Some have fixed it by heating up the pins and reflowing the solder.
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
    Aug 2007
    Winnipeg, MB, Canada
    527
    5
    I wouldn't think that a loose connection in the instrument cluster would prevent the vehicle from starting. (I could be wrong). I would be checking the battery connections.
    If at first you don't succeed, get a bigger hammer!!
    Current ride:
    2005 Dodge Grand Caravan SXT (3.8L, purchased at 108,000kms. Now at 166,000km and counting)
    Past rides:
    1997 Dodge Caravan Rallye (3.3L 242,000kms)
    2002 Chevrolet Cavalier (Base Model)
    1988 Ford Ranger (2.9L 2wd)
    1973 Dodge Cornet Wagon (318 cid)
    1965 Rambler Classic 550 4 dr (232 cid)
    1966 Rambler Classic 55 Wagon (232 cid)
    Feb 2004
    South Bend, IN
    982
    28
    Quote Originally Posted by kenmore63 View Post
    Dan is correct. The instrument cluster can produce these non-start symptoms. Bang on the dash.
    98 Town&Country LXI, 3.8L, 192k miles (sold)
    Nov 2005
    Fort Collins, CO
    3,895
    For what it's worth, when I had this happen to my 1996- I thought it was the bad solder joints in the dash as well. But it actually ended up being a bad starter motor. When it worked, it started right up, no odd noises or clicks normally associated with a bad starter. But when it didn't, wouldn't make a sound and everything else would come on in the van, but the engine wouldn't start or crank. The starter is really easy to take out and have tested.
    Apr 2009
    43
    I would almost guarantee it is the solder issue. I did mine several months ago and no problems since. There is a good write up with pics somewhere on the net on how to do it.
    Aug 2005
    57
    Quote Originally Posted by gwolff View Post
    Are you sure the clicks you're hearing aren't from the starter solenoid? Usually, when the denso starters in these vehicles begin to fail, they will work intermittently and when they don't, they will just make a clicking sound. I repaired mine easily for less than $5 by just replacing the starter solenoid contacts. The contacts are usually the only things that fail in these starters. If the clicking is coming from the starter, you can google "denso starter solenoid contacts" and will find lots of info on how to repair them. Let me know if you need any help.
    Apr 2007
    San Diego
    5,231
    Yup sounds odd but it is the case. Has all to do with the CCD data bus of which the instrument cluster is a major player.
    Apr 2007
    San Diego
    5,231
    Nothing wrong with checking the battery connections. I would even have the battery load tested. To at least partially answer your doubts about the cluster issue:
    Yup sounds odd but it is the case. Has all to do with the CCD data bus of which the instrument cluster is a major player. A failure anywhere on the data bus can create symptoms in seemingly unrelated systems. For instance some 5th generation vans have had their instrument clusters go blank because of a shorted wire in the power sliding door wire harness. The doors have a control module connected on the data bus. Who woulda thought.
