Steering wheel shakes back and forth
Results 1 to 10 of 12
Thread: Steering wheel shakes back and forth
    Jul 2011
    1
    My steering wheel shakes back and forth at any speed, you can watch it at crawl speed without touching it go back and forth. it doesn't seem any different whether braking or not nor cornering. we have replaced both tie rod ends the tires are a couple years old but look real good we even put tires and wheels off another car on it and still did the same. could it be the rack and pinion?
    Jul 2008
    Niles Il.
    10,101
    I would take the brake pads off and sand then clean along with the rotor. If that doesn't fix it, the rotors are probably lightly warped.
    '69 GTO drop top
    Jun 2009
    St. Cloud, MN
    1,667
    Check the front wheel bearings for looseness too. The causes are loose bearings, warped rotors, or bad tires with bulges in the tread area, or a bent rim.
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
    Mar 2008
    THORNTON-CLEVELEYS BLACKPOOL ENGLAND
    1,058
    Yep try all the above and get the wheels balanced properly..
    Jan 2008
    1,981
    235
    how much "back and forth" are you talking about? How old is the vehicle and what are the miles? Have you had the CV axles checked?
    Jul 2009
    1,686
    70
    Since you said you put different tires and rims on it from another car (assuming they were good), it seems warped rotors are the most likely culprit.
    Changing out the rims and tires should have netted you SOME kind of change.
    A warped rotor would drag once every revolution and produce a pulsating sensation and if severe enough, could cause your steering wheel to move back and forth.
    Alignment is another possibility...but it would have to be off pretty badly.
    I would suggest an ABS check but the chance of that causing it is really remote.
    My bet is on warped rotors(s).
    1999 Grand Caravan SE
    2006 Caravan SXT
    My own Personal Maintenance Site - minivan.tech
    By invitation Only
    Feb 2007
    Lancashire, UK
    913
    2
    My steering wheel was shaking for a while - until the left side CV joint tore itself apart.
    Replaced the drive axle, no more shake.
    Jack the van up at the front, place trans in neutral and crawl under (using axle stands) and check to see that the drive axles have no play in them.
    Easiest way is to turn the road wheel backwards and forwards with one hand while holding the drive axle with the other hand. They should both turn at the same time with no noticable free play.
    '97 Chrysler Grand Voyager 3.3 LE (UK Model) , 167,000 miles. Dual Fuel Petrol/LPG. Tow Pack.
    Now sold. New owner is using as a project ! Replaced by a 2000 Nissan Primera 2.0L Sport+
    Jul 2009
    1,686
    70
    Yep. It's definitely something up front yonder
    2006 Caravan SXT
    By invitation Only
    Sep 2009
    NJ
    326
    48
    Mine did that for a few hundred miles before the CV joint broke and dumped all the grease out.
    Currently Abusing: 1996 Dodge Grand Caravan ES 3.8L 225,000 miles (4th tranny)
    Other Rides:
    2001 Lexus ES300 44,000 miles << just picked it up!!!
    2010 Lexus RX450H 27,000 miles
    2000 Lexus RX300 AWD 164,500 miles
    2011 Lexus IS-F 6,000 miles
    Retired cars worthy to mention:
    89' Toyota Van- 296,000 miles
    92' Toyota Corolla- 232,000 miles
    94' Toyota Camry XLE- 189,000 miles (gave it to my cousin; still running strong though)
    Jan 2008
    1,981
    235
    So do you have any resolution on this?
