Overhead Console Removal
Results 1 to 10 of 12
Thread: Overhead Console Removal
    Jan 2005
    Fayetteville, NC
    9,436
    Oh 4th gen gurus:
    Can someone please point me to instructions on how to remove the overhead console on a 4th gen? There's a single sheetmetal screw/washer above the sunglasses holder door. I removed that and the back of the console was loose, and separate from the headliner. However, it's still attached towards the front somewhere. It feels loose, like it's just connected to the headliner in the front. It doesn't feel like it's screwed to the body structure anymore with this one screw removed.
    However, it doesn't want to come out, and the last thing I want to do is ruin the headliner. I'm trying to fix the broken passenger map light that Michael is also having problems with (but has a warranty to cover it ). Even if I do have to purchase a new bulb or lamp housing or whatever it is, I'd prefer to do the labor myself anyway.
    Thanks!
    Jul 2003
    High Ridge, Missouri
    4,760
    This is from the 2004 Service Manual. I hope it helps.
    REMOVAL - OVERHEAD CONSOLE
    (1) Disconnect and isolate the remote negative bat-tery
    cable.
    (2) Remove the overhead console retaining screw,
    located in the front of console.
    (3) Using your fingertips, grasp the sides of the
    overhead console and pull straight down evenly to
    disengage the two snap clips at the rear of the unit.
    (4) Lower the overhead console far enough to
    access the wire harness connectors.
    (5) Disconnect the EVIC, CMTC or CT electronic
    module and the reading/courtesy lamps electrical
    connector.
    (6) Remove the overhead console from the vehicle.
    INSTALLATION
    (1) Position the overhead console in the vehicle.
    (2) Connect the EVIC, CMTC or CT electronic
    connector.
    overhead console and push straight up evenly to
    CAUTION: DO NOT PRESS ON THE SUNGLASS
    STORAGE BIN DOOR. DAMAGE TO THE DOOR MAY
    RESULT.
    (4) Install the overhead console retaining screw,
    located in the front of console. Torque the screw to
    1.2 Nm (10 in. lbs.).
    (5) Connect the remote negative battery cable.
    Avatar: EconoVoyager Concept
    Jan 2005
    Fayetteville, NC
    9,436
    Thanks for the help! I really need to get a service manual for this van...
    I wonder if anything changed between '03 and '04? The screw on mine is what I would call the "rear" of the console, not the front as they call it. But since I have just the one visible screw in mine, I've gotta think that the "front" of the console is held on simply by clips at that point.
    Jul 2003
    4,760
    Here is the instructions for the 2002 mini van. They are NOT different from the 2004. Sorry I don't have the 2003 book.
    cable.
    connector.
    INSTALLATION
    connector.
    RESULT.
    Jan 2005
    Fayetteville, NC
    9,436
    Hey, thanks for confirming! If the instructions for '02 and '04 agree, the '03 has just gotta be the same.
    Jul 2003
    4,760
    <<Hey, thanks for confirming! If the instructions for '02 and '04 agree, the '03 has just gotta be the same. >>
    That would be my assumption also.
    Dec 2004
    Virginia
    4,029
    Jason, please let us know if you find the front is the back and the back is the front...or whatever. I don't anticipate removing mine, but it would be nice to know.
    Michael
    Centreville, VA
    Currently driving:
    Former owner of:
    Other vehicles:
    Jan 2015
    1
    Overhead Console Upgrade?
    I am curious. If I am able to obtain an overhead console that has the trip computer in it, would it be a plug-and-play swap out with an existing console that doesn't have the trip computer but just the temperature and direction display? I understand the limit of the switches for the sliding doors and hatch release (since our 2001 only has one automatic sliding door, getting a console with the extra switches will NOT make the other door or hatch open, since they are not wired or powered). I'm just wondering if a trip computer and fuel mileage computer upgrade will work with the existing wiring or not.
    Mar 2007
    2,964
    If you already have Temp & compass display, an EVIC (aka: trip computer) console should plug in. The Homelink buttons should be programmable, as well. Power door/hatch buttons will not function without the hardware.
    May 2004
    Ames, Iowa
    1,415
    8
    For a second there I thought some of the forum originals were back! Old topic, new life!
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    2012 Volkswagon Routan
    Ordered: 2015 Ford F-150 4x4
  1. Overhead console removal
    By wps in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-14-2010, 12:06 AM
  2. overhead console
    By 95cirruslx in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-01-2009, 01:16 AM
  3. Any way to fix overhead console?
    By pippo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-30-2008, 07:17 PM
  4. WTB: overhead console
    By Police Interceptor in forum Items Wanted
    Last Post: 10-18-2008, 11:18 PM
