remove oil pan--05,06,07
Results 1 to 7 of 7
Thread: remove oil pan--05,06,07
    Mar 2011
    ft lauderdale, fl
    587
    I have o6 caravan 3.8--I believe 05 to 07 is the same. What did u do to remove the oil pan. looks like a couple of brackets blocking the drop of the pan. What else. Anyone done it before?
    thanks =-scott
    Dec 2009
    MA
    284
    5
    It's not a bad job at all, the bracket you're talking about is held on by 18 or 19mm bolts (can't remember which). Once that's out of the way, it's just a matter of removing the many 10mm bolts and the pan comes down very easily.
    2011 Grand Caravan, 3.6, 144k miles
    1993 Chrysler Concorde, 3.3 150k miles
    1999 GMC Suburban k1500, 5.7, 179k miles
    2006 Pt Cruiser 2.4, 129k
    1987 Monte Carlo SS Aerocoupe 5.0, 76k
    1997 Firebird Convertible, 3.8, 53k
    1960 Corvair Sedan, 2.3, 87k
    Past Caravans:
    2005 Grand Caravan SXT, 3.8 247k miles, Sold
    2002 Grand Caravan SE, 3.3, 166k miles, Sold
    Mar 2011
    ft lauderdale, fl
    587
    ok, only one bracket. i looked up there and it looked like had to remove 2nd bracket, but there is no 2nd one, right?
    Did you use ext. for socket or swivel? anything else that i should be prepared for?
    Mar 2007
    Western Taxachusetts
    565
    27
    Have some of Popeye's spinach before you try to loosen the bolts on the brace or some pipes to lengthen your wrenches.
    Frank
    96 Grand Voyager retired
    99 DGC Sport retired at 137K miles (still running fine for my friend)
    07 T&C SWB with 34200 miles
    Mar 2011
    ft lauderdale, fl
    587
    Just got under van, do you have to remove the water intake line (the metal line) between left and right hose that then goes into the water pump. I ask because it looks like there could be a little clearance problem.
    scott
    Dec 2009
    MA
    284
    5
    Metal water line doesn't need to be moved, the pan will clear it
    Past Caravans:
    Mar 2011
    ft lauderdale, fl
    587
    Kevioll--thanks allot
    scott
