fuse box??
Results 1 to 10 of 10
Thread: fuse box??
    Jun 2011
    8
    fuse box??
    Does anyone have a diagram for the fuse box (junction box) that is inside on the drivers side for a 1998 Town and Country. I need to know what the relays are for, my manual only shows the fuses and there is no cover on the box. Thanks.
    Jun 2009
    St. Cloud, MN
    1,667
    I can't help much on the particular subject, but you could post a thread in the wanted section to get a cover for your fuse box. In fact, I think there is someone there now parting out a 1998 Grand Voyager (basically same mechanically). That way you can get your information and "put a lid on it" at the same time!
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
    Feb 2009
    Victoria BC Canada
    1,927
    This is what is under my dash, no cover I hope this helps. There is a clear cover over the fuses with no markings.
    Attachment 3727Attachment 3728
    Oct 2007
    Altamont, KS
    514
    17
    I sent some pictures of the fuse panel lid. Hopefully that helps. Will be more than happy to send the lid.
    2005 T&C Touring. 3.8L Midnight Blue. 197K Still Runs
    Jun 2011
    8
    is that the cover for the panel under the hood or drivers side under steering column????
    What I really just need to know is what relay #12 is for in the fuse box under the steering column. I got a new fuse box and on mine there is a relay in the #12 slot however on the new one there is no contacts in the plug so I need to know if is for something that I need.
    Jun 2011
    8
    Thats what mine looks like too and it doesnt look like you have a relay in the #12 slot...hummm trying to figure out what the relay is for that is suppose to be in the #12 slot???
    Feb 2007
    Lancashire, UK
    913
    2
    This is for a '97 Minivan, but they probably all use the same basic box anyway.
    If you can't figure it out from this, do a bit of elimination. Take your relay out from slot #12 and then check to see which system is no longer working.
    '97 Chrysler Grand Voyager 3.3 LE (UK Model) , 167,000 miles. Dual Fuel Petrol/LPG. Tow Pack.
    Now sold. New owner is using as a project ! Replaced by a 2000 Nissan Primera 2.0L Sport+
    Oct 2007
    Altamont, KS
    514
    17
    That is the cover under the hood. I can take some of the box under the dash. If you need I have an owners manual that I could send you. It is for a 98 voyager.
    Oct 2007
    Altamont, KS
    514
    17
    I don't know if this will be helpful. This is from the 98 voyager manual. The panel under the dash does not have a cover on it.
    Looks like info you already have.
    I don't know what position relay 12 is, but it is possible that you van has a feature that whatever the fusebox came from did not have.
    Oct 2015
    1
    I need the maunel for 99 plymouth grand voyager
    I'm trying to get the box for my 99 plymouth grand voyager online but i still not letting me see it.. Can you help me found the website please
