New radio, no sound
Results 1 to 10 of 17
Thread: New radio, no sound
    Jun 2011
    3
    New radio, no sound
    Dear all,
    I am from Portugal and recently bought a Chrysler Voyager from 2002. I am very happy because is a great machine
    I have have changed the original radio to a new one but now I donīt get any sound and everything is well connected. I have read several messages about common problem but still donīt understand were is the problem.
    Itīs possible to clarify me about this issue?
    Thanks in advance!
    Regards,
    NOL
    Jul 2008
    Niles Il.
    10,101
    Did your van originally have the Infinity radio? Though I'm not sure what was available overseas.
    '69 GTO drop top
    Feb 2011
    41
    Don't mean to jack your thread but I have the same year van (except its a T&C). Anyways my radio doesnt say Infinity anywhere on it but I do see it says "RDS" on it.
    I guess what my only question is would i have the same issues he is having? Just wondering before i start tearing it apart.
    02' T&C LX 3.3
    Jul 2009
    Tunkhannock, PA
    430
    The most common cause of a new radio with no sound, is having the "infinity" or the premium sound system in your van. Each of the speakers has it's own amplifier. Problem is, that an aftermarket radio won't be setup to tell the amplifiers to turn on. No amps turned on, no sound. Usually it's hooking up the blue "amplifier" or the blue/white "power antenna" wires to one of the wires on the original van side of the harness. I don't recall what color. There is several threads about how to power on the factory amplifiers. I'll do a bit of searching tonight when I have more time.
    2005 Kia Sorento LX 4x4 44,000mi
    2003 Chrysler T&C Limited 3.8l AWD 145,000mi Traded in 9/14/11
    2000 Dodge Stratus ES v6 179,000 sold 7/2011
    Jun 2011
    3
    Hi,
    Thanks!
    I am really a rookie on this subject...
    I know that on each speaker have an attached "object" Is this the "Infinity" amp?
    If I change all speakers I will not have this sound problem, correct?
    Thanks!
    Jul 2009
    Tunkhannock, PA
    430
    Quote Originally Posted by nol View Post
    Hi,
    Thanks!
    Thanks!
    That is your amps. Pretty nice setup if you ask me, although I would personally rather a central amp. You can replace all the speakers, and try to find out which wires are carrying the audio from your new radio to the speakers, OR you can look for which wires will kick those amps on . I haven't had a chance to look up the wiring for the van (I am running stock Infinity/DVD setup), but I had the same issue with my Stratus
    when I changed the radio. The car side of the harness needed one of the blue wires from the radio side.
    Jul 2009
    Tunkhannock, PA
    430
    Ok, so not quite as easy as just connecting a wire in the dash behind the radio... But still pretty simple. You can run this from the blue or blue/white or red on the radio, or tap into any "switched" power. Make sure whatever source you choose, has 12v with the key on ACC, but NOTHING when the key is OFF. Otherwise, you will have a nice dead battery in the morning :-p
    http://forum.chryslerminivan.net/sho...et-stereo-help
    Post #3
    "The amp relay is in the Relay/Fuse box located under the hood. The amp relay is the one labeled NBS which stands for Name Brand Speakers.
    If you are trying to install an after market radio in a 2001 Chrysler Town and Country, you may notice that no sound comes from the speakers. This is because the single wire that is connected to the factory radio sends a signal to the Bus which tells the relay to turn on - powering the factory amp. I bypassed this by running a wire from the red Acc power wire on the radio to the relay. Connect the wire to pin number 87 on the relay. When standing in front of and facing the van, pin number 87 is the pin, on the NBS relay, which is closest to you and furtherst right"
    Jun 2011
    3
    THANK YOU SO MUCH FOR YOUR CLARIFICATION!!!
    Now I get the picture!
    Regards from Portugal!
    Apr 2009
    Bronx, New York City.
    576
    I would change the speakers but thats up to you.
    Silver 2002 Chrysler T&C EX 3.8
    Just hit 100,000 miles and counting.
    Aug 2015
    17
    Will pinning the 87 on the NBS this also work on an 05 TC w/RB1 which I'm replacing with an aftermarket DVD player and all the bells and whistles?
