01 Caravan air bag light on
Results 1 to 10 of 14
Thread: 01 Caravan air bag light on
    Jul 2009
    Windsor,Ontario
    314
    31
    I know, I know.. "Another one with the airbag light on??!! Read the posts on this!!"
    Believe me I looked, but couldn't find the answer.
    '01 Grand Caravan 180,000km(110,000 miles approx.)
    A while ago I was told by the dealership that the clock spring was bad, so yesterday I changed it, along with the broken multi-function switch. Fixed one problem... turnsignals are canceling once again but the airbag light is still on. Only error code returned by the key method is that the battery has been disconnected (P1684). Do I need a code reader to clear the airbag light or do I have another problem in this area?
    Thanks in advance
    Brian
    Current:
    '16 Dodge Grand Caravan Crew Plus - The "Bosses" NEWest ride
    '15 Dodge Journey SXT Limited - Current ride
    Retired:
    '09 Nitro R/T - The "Bosses" NEW ride
    '07 Grand Caravan
    '09 Charger - The "Bosses" ride
    '01 Grand Caravan - Gone, but never forgotten.
    '92 Ford Taurus
    '88 Caravan - You never forget your first one.
    '85 Ford Tempo
    '76 Dodge B300 - Good times
    '69 Ford 1/2ton Pickup(F100?)
    '74 Mercury Comet
    '77 Plymouth Fury Salon - Old green clunker
    Jul 2008
    Niles Il.
    10,101
    You need a DRB tool to read the air bag system codes. The fact that the light is on likely means the system knows where the fault is.
    '69 GTO drop top
    Jul 2009
    Windsor,Ontario
    314
    31
    Thanks Andy, what I thought. A friend has one, hopefully we can hook up this week.
    Brian
    Current:
    Retired:
    '07 Grand Caravan
    '92 Ford Taurus
    '85 Ford Tempo
    '74 Mercury Comet
    Jul 2009
    Windsor,Ontario
    314
    31
    OK, had a friend check for errors today and he said there were no stored errors. He used an ODB code reader, not a DRB.. is there a difference? In any event, going to have a look at some weak points in the wiring that I was told about. Apparently weak points exist in the harness under the seats, and also in the dash to the right of the radio.
    Will see what we can find.
    Brian
    Current:
    Retired:
    '07 Grand Caravan
    '92 Ford Taurus
    '85 Ford Tempo
    '74 Mercury Comet
    Jul 2008
    Niles Il.
    10,101
    A DRB is a complete system scan tool, a very expensive item that normally only dealers, body shops, and high end mechanics have. The OBD only reads engine related codes.
    '69 GTO drop top
    Jul 2009
    Windsor,Ontario
    314
    31
    WoWoW!!! Took a quick look on Fleabay and these things run around $3,000 to start.. Guess it's back to " a friend of a friend " who is the service manager at the stealership.
    Brian
    Current:
    Retired:
    '07 Grand Caravan
    '92 Ford Taurus
    '85 Ford Tempo
    '74 Mercury Comet
    Jan 2010
    7
    Hi Brian,
    I almost have the same problem, instead of new thread, I am going to put details here.
    I have 2001 T&C Limited w/150.000 miles on it.
    Airbag light comes on after 5-10 minutes driving, all the time. when I first start no light. after some time it is on.
    So I took the van to dealer to see. Report was "Airbag Module Loses Connection with Instrument Cluster" this turns the light on and turns off the airbag system.
    They said I need a new cluster, circuit board is fault... $900...etc...
    First; I check the wiring it self between cluster and the AB Module. it is the PCI Bus, White with Violet stripe. connection was OK.
    Second; I installed a new clock spring. AB light still on.
    Third; I got a used Cluster from junkyard and installed. AB light still on.
    Fourth; I removed the cluster, re-solder the socket pin connections. AB light still on.
    Also, for the error codes: check the cluster codes. engine off; press and hold the trip button, until you see lights come on. and follow the odometer. This is cluster self diagnostics. it tells you if you have any error codes with it.
    I had these codes with cluster,
    100.1 ABS Communication Fault
    100.5 ORC Communication Fault
    100.6 SBEC/DEC/MCM Communication Fault
    400.1 Improper power down Detected
    So anybody has any ideas,
    Jul 2009
    Windsor,Ontario
    314
    31
    Thanks etek. Did the check today and, fortunately, no errors. That was pretty neat tho, watching all the gauges move up, and then back down, and the various lights come on.
    Brian
    Current:
    Retired:
    '07 Grand Caravan
    '92 Ford Taurus
    '85 Ford Tempo
    '74 Mercury Comet
    Jul 2010
    Indiana
    5
    BrianS - Any updates?
    My airbag light just came on and I'm just beginning my rootcause troubleshooting.
    Thanks,
    Josh
    Feb 2007
    Maricopa County, Arizona
    104
    2
    Any news, anybody? We have this with our 2007.
    2007 Chry. T&C, 2001 PT Cruiser Touring, 1996 Dodge Cummins 5 sp., 2014 Subaru Outback 6 sp. MT.
