Rust through on doors
Results 1 to 7 of 7
Thread: Rust through on doors
    May 2004
    5
    I have a 96 T&c and there is bad rust on the passeneger sliding door and the drivers door at the bottom. This is caused by a poor design in the weatherstripping on the doors, it holds the water in place against the doors and then it rusts. Has anyone had this problem? Has Chrysler done anyhting to help with the repair of the rust?
    Nov 2003
    936
    It may be due to so called "rust proofing" someone did to it and clogged the drains. If you keep the drains clean this isn't much of a problem. Bigger issue is the strut tower behind the battery and the rear wheel arch under the gas door.
    Jun 2004
    rochester,ny
    748
    7
    rust
    I have a 96 Voyager and there isn't a spot of rust on it and I live in an area where salt is king . I think the secret is to keep it washed even in the winter and keep it waxed a couple times a year . I doubt you'll get chrysler to do anything on a 9 year old van , rust thru warranty certainly isn't 9 years , think it's something like 6 years or 100000 miles whichever is first .
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    48000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
    Dec 2004
    Seattle Area
    14
    Rust
    Hello from the 2nd sunniest place on earth
    I'm sorry It's Seattle.
    I'm not sure where you live.
    I have not found any rust on my '97 AWD TC.
    I keep it very clean and try to rinse all residue from the small amount of road salt from my car ASAP.
    I rinse the underside about every 3rd washing. :
    look for residule mud and gunk in all the hiding spots, wheel wells, door welds at the bottom, anywhere water @ mud will collect.
    Visit Chicago and you will notice hardly any cars 10 yrs old.
    Lots of snow and salt.
    Good luck
    Jul 2003
    High Ridge, Missouri
    4,760
    Hey Bobo5727. I know you can see the rust and it IS THERE. However this is not a common problem on the mini van. Not to say that you might have gotten a van with a panel that was not prepared and coated and painted correctly. These thing can happen. However it is NOT a common problem.
    You can talk to the dealer (if you bought it new) and see what they may do but I don't think you will find any help there. I am sorry to say.
    I agree with Larry when he says that your door drains may have been clogged up. I see that alot with aftermarket rust preventive add-ons and people who park under trees alot. The junk/leaves get down inside the doors and windshield areas, block drain areas and collect water. Then the water is held to the vehicle surface and causes the rust reactions.
    I know this does not help YOU , however I am with the rest on keeping my vehicles clean. I even clean inside the door sills and all other surfaces everytime I wash my car and I wax the whole area at least once a year.
    Good luck to you.
    Avatar: EconoVoyager Concept
    May 2004
    5
    rust on door
    The rustrpoofing was done by the dealership. I'n going to see what it will cost to get it fixed.
    Dec 2004
    Virginia
    4,029
    Quote Originally Posted by bobo5727
    If the rustproofing was done by the dealership, then maybe there is a warranty on the RUSTPROOFING, rather than the car. If you still have the documents you received when you bought the car, that may help.
    Michael
    Centreville, VA
    Currently driving: 2015 Jeep Cherokee Trailhawk
    Former owner of:
    2005 Dodge Grand Caravan SXT, 129K mi.; 2008 Nissan Quest, (2008-2010, 25K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi);
  1. Rust prevention - oil in doors?
    By cb250rs in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-30-2009, 06:09 PM
  2. Trust Doesn't Rust
    By Chrysler1924 in forum The Fireplace
    Last Post: 03-26-2009, 05:15 PM
  3. Seen a 4 gen rust bad = sad
    By Alex in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-26-2006, 02:01 PM
