2005 Town and Country 3.8 (94,200) - P0420 Code
Results 1 to 4 of 4
Thread: 2005 Town and Country 3.8 (94,200) - P0420 Code
    May 2009
    Kentucky
    100
    72
    I got the P0420 code last night...Should I start by replacing the downstream O2 sensor, the upstream was replaced recently. The downstream sensor is original, cat is original? Can i damage the car by driving it until I get this fixed?
    Apr 2007
    San Diego
    5,208
    First try resetting the code and see if it comes back. Disconnect the negative battery cable for 2-3 minutes or reset it using a scanner. If it comes back and you want to swap parts, the aft O2 sensor is one candidate: http://www.obd-codes.com/p0420
    Your van should be ok till this is fixed but don't wait six months. If the SES light starts flashing, don't drive it anywhere except to get it fixed. It means the catalytic converter is potentially overheating and may need to be replaced if you keep driving.
  4. The Following User Says Thank You to RIP For This Useful Post:
    L22(03-20-2011)
  5. #3
    May 2009
    Kentucky
    100
    72
    I'm going to replace the downstream sensor and see what happens....Is it difficult to replace the cat on the 2005 (3.8) ?
  6. Remove Advertisements
  7. #4
    Dec 2009
    MA
    284
    5
    Not difficult if you have any experience with exhaust work. The most challenging part is removing the 4 bolts where it attaches to the exhaust manifold on the back of the engine. They're very difficult to access and most likely very corroded. I wound up cutting or breaking them all off to remove.
    2011 Grand Caravan, 3.6, 144k miles
    1993 Chrysler Concorde, 3.3 150k miles
    1999 GMC Suburban k1500, 5.7, 179k miles
    2006 Pt Cruiser 2.4, 129k
    1987 Monte Carlo SS Aerocoupe 5.0, 76k
    1997 Firebird Convertible, 3.8, 53k
    1960 Corvair Sedan, 2.3, 87k
    Past Caravans:
    2005 Grand Caravan SXT, 3.8 247k miles, Sold
    2002 Grand Caravan SE, 3.3, 166k miles, Sold
