Install tag mounted back up camera on '08 Grand Caravan
Results 1 to 9 of 9
Thread: Install tag mounted back up camera on '08 Grand Caravan
    Mar 2011
    4
    Just purchased a Nextar wireless back up camera that mounts on the the license plate bracket. Looking for the best way to connect the wiring?
    Apr 2008
    New England, USA
    1,659
    20
    Quote Originally Posted by Lambstangle View Post
    Is this the product you're talking about?
    http://www.nextar.com/images/Product...SG%20(Eng).pdf
    2009 Dodge Grand Caravan SXT (3.8L), Light Sandstone Metallic, 125K miles
    2005 Volvo XC70, 160K miles
    Previous van: 2002 Chrysler T&C, eX (3.8L)
    Mar 2011
    4
    Nextar 14-BC WIRELESS TAG PLATE MOUNTED CAMERA
    How do you thread the wires through the tailgate or how do you dismantle the tailgate to make the connection to the brake system?
    Mar 2011
    4
    Yes it is. I know it is wireless to the gps receiver and activates when you apply the brakes, but it must be wired to the brake system in a professional manner.
    Apr 2008
    New England, USA
    1,659
    20
    I think the idea is that it activates when you are in Reverse, not when you apply the brakes.
    You will need to locate a harness that carries power to the reverse lamps, splice into that, and route it cleanly to the camera. I don't have any definitive instructions for you. Perhaps someone else here is more familiar with the wiring back there.
  8. The Following User Says Thank You to jgiurleo For This Useful Post:
    UN4GTBL(10-11-2015)
  9. #6
    Mar 2011
    4
    Thank You
  10. #7
    Aug 2008
    122
    I installed a backup camera in my Corvette. I hooked the camera power and ground wires to the backup lights, so that the camera would be powered when the car was put into reverse. My radio was capable of displaying the camera and required a trigger to switch to the camera input. This is typically supplied by the reverse gear indicator wire. In my case, the car was a stick shift and had no reverse gear indicator, so I connected the trigger wire to the backup lights as well. It works great. You should be able to power the camera by taping into the backup lights. If you have the unit listed in the previous link, the monitor looks like it plugs into the cigarette lighter for power and automatically comes on when it receives a signal from the camera. The hardest part would be to run the wires from the camera mounted on the tailgate over to the backup lights on the body. I think you will have to remove the interior panel of the tail gate in order to do this. Hope this helps
    Phil
    2008 T & C Limited
    Mygig
    Towing Package
  11. #8
    Oct 2015
    1
    Exclamation 2005 dodge grand caravan, new headunit and backup camera install
    I installed a new after market head unit and backup camera on my 2005 dodge grand caravan. Here is the video clip.
    https://www.youtube.com/watch?v=SQ5ZQezqf-Q
  12. #9
    Jul 2009
    Pickering, ON
    2,279
    35
    4.5 year old thread.
    sent from my Univac using Assembler.
    http://forum.chryslerminivan.net/image.php?type=sigpic&userid=13818&dateline=124855  5576
    ____________________________
    08 Grand Caravan SXT Silver 3.3L
    07 Impala SS, 323 cubic inches divided into 8 mighty pots.
  13. The Following User Says Thank You to madbrad For This Useful Post:
    UN4GTBL(10-11-2015)
