very high idle mystery- not the IAC valve
Results 1 to 5 of 5
Thread: very high idle mystery- not the IAC valve
    Jun 2010
    5
    My 2001 Chrysler Town & ciuntry suddenly developed a racing idle, around 3K in neutral.
    I got code P1294 which suggests a vacuum leak or a bad IAC valve, right?
    I changed the IAC valve and it did not fix the problem.
    What next?
    Anyone know what the voltage is supposed to be at the plug to the idle air control valve?
    thanks
    Dave Silva
    Oct 2003
    Niagara Ontario
    825
    Look for a vacuum leak.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
    Jun 2009
    Jefferson City, TN
    3,051
    Could be a vacuum leak. Also if your throttle body is REALLY covered over with gunky carbon build-up it may not be letting the throttle plate close all the way. If you try to manually close the throttle body, does the idle go down? Does the gas pedal stick any when you first press on it?
    Jeff
    Current:
    Previous minivans:
    Jul 2008
    Niles Il.
    10,101
    Enough airflow AND computer knowledge to run 3k rpms has to be the throttle plate stuck open somehow. I would pull the intake hose and take a look as suggested by jgbat.
    '69 GTO drop top
    T&CFan Guest
    Or maybe a varmint got wedged in there trying to get out of the cold.
  1. high pressure ac hose valve
    By pippo in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 07-11-2010, 08:12 PM
  2. Automatic idle speed (idle speed control valve)
    By vgb14 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-04-2010, 11:11 AM
  3. high pressure port valve=charger valve???
    By mewant2b in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-24-2008, 04:41 PM
  4. EGR valve at 25K on a 2005? Rough Idle
    By turbotec in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-25-2008, 06:23 PM
  5. Tuned up today, now have high idle
    By emb2580 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-15-2007, 09:53 PM
