garage door opener programing
Results 1 to 7 of 7
Thread: garage door opener programing
    Dec 2010
    Oahu, HI
    70
    My T&C did not come with a factory owners manual. If its like any of my other jeeps I guess Id just hit the 1 and 3 buttons till it flashes then hold the button to program with the garage door opener at the same time?
    08 Town & Country Touring, Black A6
    96 Camaro Z28/SS, Black M6 ,4.10 rear and all the SLP goodies...
    51 Buick Super Eight, 263ci straight eight, Dynaflow, True Survivor
    Jan 2010
    Port Neches, Texas
    82
    1
    Call Homelink at 1-800-355-3515 or go to www.Homelink.com.
    C.B.
    Jan 2011
    Illinois
    63
    Depending on the brand/age of your opener, you may have to push a button on the opener itself to allow the homelink to learn the code.
    2009 Chrysler T&C Touring 4.0L
    2009 Dodge Ram 1500 TRX4 CrewCab Hemi
    Past Vehicles:
    2005 DGC 3.8
    2003 Ram 1500 4wd QC 4.7
    2001 Dakota 4wd CC 4.7
    2001 Dodge Neon 2.0 auto
    2000 Plymouth Neon 2.0 w/ manual trans
    1996 Dakota 2wd 3.9
    1991 Daytona 2.5 NA Auto
    1989 Dynasty 3.0
    T&CFan Guest
    Here's info from '10 DVD (legal stuff at beginning said it's okay to print, so figure it's okay to reference here):
    Should erase all current settings of HomeLink first by pressing and holding the two outside buttons for up to 20 seconds until the red indicator flashes.
    - Make sure your van is parked outside the garage door.
    - Turn the ignition switch to the ON/RUN position.
    - With the battery side of the handheld transmitter held away from the HomeLink® button you wish to program, place your handheld transmitter 1 to 3 in (3 to 8 cm) from that HomeLink® button while keeping the indicator light in view.
    - Simultaneously press and hold both your chosen HomeLink® button and the handheld transmitter button until the HomeLink® indicator changes from a slow to a rapidly blinking light, then release both the HomeLink® and handheld transmitter buttons. Watch for the HomeLink® indicator to change flash rates. When it changes, it is programmed. It may take up to 30 seconds or longer in rare cases. The garage door may open and close while you train.
    - Press and hold the just-trained HomeLink® button and observe the indicator light. If the indicator light stays on constantly, programming is complete and the garage door (or device) should activate when the HomeLink® button is pressed.
    If the indicator light blinks rapidly for two seconds and then turns to a constant light, then you have a Rolling Code System, so more steps.
    To program a Rolling Code System:
    - At the garage door opener motor (in the garage), find the “Learn” or “Training” button. This can usually be found where the hanging antenna wire is attached to the garage door opener motor. The name and color of the button may vary by manufacturer. It is NOT the button normally used to open and close the door.
    - Firmly press and release the LEARN or TRAINING button. Note: You have 30 seconds in which to initiate the next step after the LEARN button has been pressed.
    - Return to the vehicle and press the programmed HomeLink® button twice (holding the button for two seconds each time). If the device is plugged in and activates, programming is complete. If the device does not activate, press the button a third time (for two seconds) to complete the training.
    Like cbwilsha said above, you can call toll-free 1–800–355–3515 if you need help or, on the Internet go to www.HomeLink.com,
    If you want to program one or both of the remaining two HomeLink® buttons, repeat each step for each remaining button, except of course for the "erase the channels" step. Don't want to wipe out what you just programmed!
    Dec 2004
    Virginia
    4,029
    Quote Originally Posted by chevydude97 View Post
    The owner's manual (for all vehicles model year 2004 and later) is available online as an adobe acrobat pdf, for free, at chrysler.com. Click on "for owners" and look for "owner's and service manuals." You don't even have to be an owner--they don't ask for a VIN or any other identifying information.
    Michael
    Centreville, VA
    Currently driving: 2015 Jeep Cherokee Trailhawk
    Former owner of:
    2005 Dodge Grand Caravan SXT, 129K mi.; 2008 Nissan Quest, (2008-2010, 25K mi); 2003 Grand Caravan Sport, 3.8L, (2004-2008, 106K mi); 1995 Plymouth Grand Voyager SE "Rallye", 3.3L (1995-2004, 169K mi); 1988 Dodge Caravan SE, 2.5L I4 (1988-1995, 99K mi);
    Mar 2008
    Southern WI
    384
    5
    Quote Originally Posted by mmahamm View Post
    I keep all of our virtual owner's manuals right on the desktop anymore. It's much easier reading them here than in the (cold) garage.
    Pat
    17 Pacifica Touring L
    Previous vans:
    08 T&C Touring
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Dec 2010
    Oahu, HI
    70
    hey much thanks for all the quick replies!
  1. setting the universal garage door openers?
    By ace spaid in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-27-2015, 03:11 PM
  2. Key Programing
    By itrekrm in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-27-2010, 12:34 AM
  3. programing a key
    By dwayne30 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-03-2009, 11:42 PM
  4. garage door opener
    By IAfarmer in forum The Fireplace
    Last Post: 12-09-2008, 06:31 PM
