Help! Codes P0442 + P0455
Results 1 to 4 of 4
Thread: Help! Codes P0442 + P0455
    Dec 2008
    35
    5
    It started out for awhile I had code P0442 only. After about a year, I re-checked and now have both P0442 & P0455. I took my van to my mechanic and he went after it using the smoke machine, first from the engine end of the system then from the filler on the tank. He found no visible leakage. This troubled us because the P0455 is supposedly a large leak.
    Is it possible that something else has occurred in the system that trips these codes? We have cleared the codes they come right back on starting the engine!
    '92 Plymo GV SE 3.3, R.I.P. [130,000 miles, 2 trannies, threw a rod]
    '94 Dodge GC SE 3.3, R.I.P [160,000 miles original tranny]
    '02 Dodge GC Sport 3.3 [165,000 miles and counting!]
    Apr 2007
    San Diego
    5,264
    Here's a short video of the smoke check on a 2002 caravan with the P0442 and P0455 codes. Maybe the mechanic missed something: http://www.youtube.com/watch?v=CSn0ljUS6kI
  4. The Following 2 Users Say Thank You to RIP For This Useful Post:
    FamilyGuy76(05-28-2011), sheldon!(01-15-2011)
  5. #3
    Sep 2007
    9
    thanks RIP - my mechanic (not a dealer) did a smoke test and found P0455 to be a rusted fuel filler neck. Neck was rusted way up top near the actual fill point. I paid him 80 bucks to diagnose and I bought the part from a dealer for 180 to fix. Dealer had the neck in stock and the junk yard was out of stock leading me to believe that this might be a common problem. New fuel filler kit comes with attached piping and small reservoir in addition to the rubber hose that fits to the gas tank and a new gas cap. Replacement was very easy through the wheel well. Those finger removeable vent hoses are vunderbar.
  6. Remove Advertisements
  7. #4
    Apr 2007
    San Diego
    5,264
    Thanks for passing along the info. Good to hear a successd story.
  1. Dealer repair for EVAP Leak p0442 p0455 (pics)
    By Dave Maher in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-11-2012, 07:24 PM
  2. Failed emissions with errors P0442 and P0455.
    By tremendocojones in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-02-2009, 06:38 AM
  3. Help, Key Codes: P1684, P0442, P0456
    By ron semko in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-23-2008, 11:17 PM
  4. P0442 & P0455
    By Gino45 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-07-2007, 05:20 PM
  5. New code...P0442
    By psal2 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-07-2007, 03:48 PM
