Position of internal fuse box
Results 1 to 5 of 5
Thread: Position of internal fuse box
    Jan 2011
    3
    Cannot locate fuse box described in owners guide as " in lower right side of intrument panel"
    Want to check fuse for intrument cluster as have lost lights and speedo etc
    Car is UK based and right hand drive, thanks
    Jun 2009
    Jefferson City, TN
    3,051
    In the US, the fuse box is located under the dash on the left side. Since your owners manual says it is on the right side, look under the steering wheel, next to the gas pedal, under the dash, for a plastic access panel.
    Jeff
    Current:
    Previous minivans:
    Jan 2011
    3
    Thanks, have had a look and remains a mystery,drawing in owners guide indicates a panel but nothing to find, have taken trim out and had extensive look, other UK threads with same problems, local garage could not find it.
    My real problem is loss of cluster function, have bought used cluster on eBay and that is not working either. Car drives fine without cluster, also other fault is no turn signals
    Jun 2009
    Jefferson City, TN
    3,051
    Quote Originally Posted by Ducky View Post
    Look under the dash on the left (your passenger) side. It may be there and the book is printed wrong. Either way, it is under the dash in the US. Sometimes there is an access panel on the end of the dash that you can only see with the doors open. Look there as well.
    Jeff
    Current:
    Previous minivans:
    Feb 2009
    McDonough, GA
    53
    My Haynes manual also said I had a fuse box under my dash, behind the knee pad panel. No such animal exists. The fuse box is under the hood. Try pulling the IOD fuse in the panel under the hood. That is to the body control module. Pull it and leave out for maybe 10-15 minutes. Then replace and see if it has reset (i.e. your interior lights come back on). Recently had an incident in which my temp control and interior lights went out. Read about the IOD fuse on this forum, tried it, and VOILA!!
    '01 T&C LXi -200k miles
    '84 Celica - 200K+
    '95 Accord - 135K
  1. Help with fuse position in power center
    By fdm2000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-13-2010, 11:53 AM
  2. One Piece Internal floor mat
    By jamesybutler in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-12-2009, 11:59 PM
  3. Internal Air Filter
    By 2timeDodgeCaravanowner in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-26-2008, 05:25 PM
  4. Finding the internal fuze box on a 2002?
    By dave76528 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-29-2008, 01:24 AM
  5. Sales Position Available
    By Glen Millar in forum Chrysler Minivan Fan Club Site News
    Last Post: 01-21-2004, 05:36 PM
