how do I replace the altenator on a 2004 town and country?
Results 1 to 10 of 19
Thread: how do I replace the altenator on a 2004 town and country?
    Jan 2011
    2
    Does anyone know where I can get step by step directions on replacing the alternator on a 2004 t&c? I have done it on other vehicles but never a mini van. The repair shop wants over $400 to do the work and that seems pretty crazy to me but im new to this van. Any advice would be greatly appreciated.
    Jan 2011
    Central PA
    26
    REMOVAL
    1. disconnect the neg term
    2. Disconnect the push-in-field wire connector from the back of the generator
    3. Remove the nut holding B+ wire terminal to the back of the generator
    4. Remove the B+ wire from the generator
    5. Raise and support the vehicle
    6. Remove the right front lower splash shield
    7. Remove the serp belt
    8. Remove the lower oil dipstick bolt
    9. Remove the wiring harness from the dip stick tube
    10. Remove the the 3 mounting bolts
    11. Lower the vehicle
    12. Remove the oil dipstick tube from the vehicle
    13. Roll and remove the generator
    INSTALLATION
    Reverse the procedure... Any problems PM me... Good Luck
    Taken from AllData 9.8
    Jan 2011
    Central PA
    26
    That is for the 3.3 BTW I don't see how the 3.8 would be much different... LMK
    Apr 2010
    Eastern Nebraska
    688
    I think also that those instructions would assume that the van has an EGR valve in the way of removing the alternator - generally what you've got on those vans is two alternatives:
    1) remove/move the EGR valve to get the alternator out.
    2) remove/move the dipstick tube to get the alternator out.
    I'm going to be doing a similar job on my 2005 (3.8 w/EGR) in the near future, so I'm weighing my options on what way to get the alternator out as well. The nice thing for me is that my alternator is still charging just fine, so I'm not pressed into doing the job immediately.
    Nate
    '05 Town & Country Touring
    3.8L 198,000 mi
    Jan 2011
    2
    Thanks for all the help.
    Nov 2007
    347
    15
    It's hard to get the EGR valve out without first removing the alternator. When I changed my EGR valve, I struggled so much to get the bottom bolt off that I finally decided to just take the alternator off. It was pretty easy to do.
    Removing the dipstick tube is very easy.
    Quote Originally Posted by nate95366 View Post
    Nate
    2004 Chrysler Town and Country 3.3, 292,000 miles
    Jan 2011
    Central PA
    26
    Whichever way you decide to go about doing it, I wish you the best....
    I have worked on many vehicles and find that AllData provides the fastest and least aggravating way to complete the job.... Just stock up on the beer and buddies you'll be okay....
  10. The Following User Says Thank You to GreyGhost96 For This Useful Post:
    michaelsurfs(05-02-2015)
  11. #8
    May 2015
    1
    Easier access to alternator and getting in/out without removal of EGR or dipstick
    Got an easier fix on this fellas. Take the crossbar support out above the radiator fans (if I recall correctly, two bolts on each side). There is one harness to release on the fan on the alternator side and it literally slides right out. You have all the space in the world to remove the alternator as well as put it back it without any B.S. Once the alternator is back in, tightened down, serpentine belt back in, etc, slide the fan back into it's slot, tighten it down with the one bolt holding it in place, connect the electrical harness, replace the frame crossbar (this is the same cross bar that holds your hood release, so it's a good time to grease that bugger down while you are at it). Voila, easy peasy, no removing EGR valve, no removing dipstick, nothing. Taking that crossbar and fan out took maybe 5 minutes.
  12. The Following 2 Users Say Thank You to trooperchix For This Useful Post:
    gusc(09-16-2016), Stimus(09-08-2016)
  13. #9
    Sep 2016
    1
    great advice but I always have trouble with the electrical connectors. What's the secret to that and de-tensioning the belt?
  14. #10
    Apr 2012
    Seattle, WA
    862
    Quote Originally Posted by lu201 View Post
    For the belt, many auto parts stores have "tool loaner" programs that you can get a belt tensioner tool for. I just bought one at Harbor Freight and called it done. <$30
    For the electrical connectors, if they have the (red) locking slides on them, release the lock and push down on the tab on the female connector while pulling on the male connector. The other style has the clip on the female side that engages the tab on the male side, and you need to lift the clip away from the connector to release the connection
    -Doug
    '01 Town & Country Limited, 150K miles & still rolling
    '97 Saturn SL2
  15. The Following User Says Thank You to douggro For This Useful Post:
    Stimus(09-08-2016)
  1. 2004 Chrysler Town & Country Limited....auto trans....to service or not to service?
    By bgdave in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-06-2014, 07:58 PM
  2. 2004 Town and Country air bag light
    By dsharp1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-03-2013, 03:08 PM
  3. 2004 Town and Country Rack Knocking Noise
    By 2ez24get in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-18-2010, 07:15 PM
  4. Change out OIL PAN from 2004 Town & Country
    By AVOLIN in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-08-2009, 01:25 AM
  5. How do I replace 2004 Town and Country Overhead Console Lights
    Last Post: 02-06-2008, 11:39 AM
