Brake warning light,on intermittenly,not abs light
Results 1 to 6 of 6
Thread: Brake warning light,on intermittenly,not abs light
    May 2009
    TUCSON,AZ
    5
    The brake light started coming on and then off, it got more frequently. I looked in the Haynes manual no mention of anything would help narrow it down, I have meters some knowledge of electronics. The wiring diagrams just show drivers for light? The brakes seem to work OK. Had the codes read and everything looked OK, except the ABS system indicated an low ref voltage. Not sure what the connection, could be with the two systems, as the ABS light is not on and there is no codes.
    Feb 2010
    143
    31
    This began on mine recently and it was simply the low fluid level sensor triggering it.
    2006 Caravan - 3.3l - 4 spd auto - 110k
    1997 Caravan - 3.0l - 3 spd auto - 88k miles - TOTALED on 8-31-12
    Jul 2009
    881
    8
    Quote Originally Posted by wrench1368 View Post
    That (fluid level) should be the first thing to check.
    Leon
    '97 Town & Country LXi
    T&CFan Guest
    Just a thought... it could be the disc pads have worn down such that they displace less brake fluid in the system, so the amount in fluid in the brake reservoir goes down and triggers the warning indicator.
    Apr 2009
    Empire State
    3,814
    check the parking brake pedal/switch too..
    Oct 2007
    Vermont
    1,332
    Our vans have done this when the fluid level gets low. It will do it more in the cold weather. After a few stops, and the engine warms up the fluid expands enough to raise the float enough to turn the light off.
  1. (!) warning light for Parking Brake
    By Lord Plecostomus in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-01-2010, 09:53 PM
  2. ABS Warning light?
    By Gumby in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 08-26-2008, 10:50 PM
  3. ABS Warning Light
    By Dobie93 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-13-2008, 04:10 PM
  4. Brake warning light?
    By kenmore63 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-08-2007, 11:42 PM
  5. oil warning light
    By Audifan1989 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-13-2007, 03:14 PM
