Oil light on, Oil light off
Results 1 to 7 of 7
Thread: Oil light on, Oil light off
    Jan 2004
    DC area
    528
    59
    What's it mean when you start the van (cold) and the oil light comes on, but when you shut the engine off then turn it back on, the light goes out and stays out. It will stay on even after it warms up, but always goes out if you turn engine off and then on.
    Scott
    2015 Dodge Grand Caravan SXT
    3.6L-V6, 25,000 miles.
    Previously had:
    * 2005 Dodge Grand Caravan SXT 3.8 - 185K miles
    *1999 Plymouth Grand Voyager SE 3.3L-V6 FFV, 141K miles.
    *1999 Braun Entervan III (Dodge Grand Caravan modified for wheelchair users) - 65k miles 3.3L V6 FFV
    *1988 Plymouth Grand Voyager SE 3.0 V6 with 3 spd tranny -168K miles on it.
    Jul 2008
    Niles Il.
    10,101
    Well, if your engine hasn't failed from lack of lubrication, I would say your pressure sending unit is bad. Fairly common failure too.
    '69 GTO drop top
    Jun 2009
    Jefferson City, TN
    3,051
    If the engine knocks or makes any sounds, you may have an engine issue.
    However I'd be willing to bet the engine is quiet all the time. Seeing how that is most likely the case, I'd say the oil pressure sending unit is going bad. Put a new one in it. Also if you live around squirrels, I'd check the wiring for the sending unit also.
    Jeff
    Current:
    Previous minivans:
    Apr 2009
    Empire State
    3,786
    any chance this started soon after an (engine) oil & filter change? (if so what brand filter?)
    Oct 2003
    Niagara Ontario
    822
    I had this problem on my van, It also set a code that did not display the check engine light. I simply replaced the Oil pressure sensor and the problem is gone for good.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
    Oct 2008
    1,840
    4
    Like was said, replace the sender.
    Or attach a mechanical oil pressure tester.
    Jan 2004
    DC area
    528
    59
    Thanks much! It was not right after an oil change, but not long after one. Maybe a week.
    Scott
    Previously had:
  1. ABS light, Fuel Light + nonworking gauge after Maaco painted van. Any ideas?
    By mishagos in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-11-2011, 10:26 PM
  2. Brake warning light,on intermittenly,not abs light
    By oldman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-23-2010, 11:23 PM
  3. ABS Light, Air Bag Light , No cluster gauges
    By seaspice in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-07-2009, 03:16 AM
  4. Radio shorted out then Battery Light & ABS light came on. WHY??
    By ilovemyscents in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-25-2009, 02:07 AM
  5. Oil Light
    By hope in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-31-2006, 02:52 PM
