Coolant leak - Drivers side front of van
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
Thread: Coolant leak - Drivers side front of van
    Aug 2008
    60
    4
    I am loosing coolant. At first at thought maybe it was the water pump but I am getting drips on the garage floor on the drivers side of the van towards the very front. Is there a hose or pipe that I should check first when looking for the leak?
    It seems like these van's develop a lot of the same problems so I thought maybe someone else had a leak in a similar spot that would at least give me a good starting point.
    Thanks for any help!!!!
    2002 T&C LX
    3.3L
    158,000 Miles
    Mar 2007
    2,956
    Given that location - radiator, or hose leading to it.
    -Jim
    Jul 2007
    Pittsburgh, PA (West)
    22
    Has your water pump been changed before? – If not you are way overdue.
    To be safe replace the Lower radiator hose, metal coolant tube and the water pump.
    The metal coolant tube is pictured in the instructions at the bottom. It’s very common for them to rust.
    Here is the part:
    http://cgi.ebay.com/ebaymotors/ws/eB...8307&viewitem=
    The water pump, Lower hose and 2 clamps are available everywhere and not expensive.
    Replace your coolant while you are doing this.
    Instructions that I followed (made the job pretty easy):
    http://www.metacafe.com/watch/874963...p_replacement/
    Gene from Pittsburgh
    2002 Town & Country LXi - 93K
    2003 Buick Regal LS - 133K
    2004 Ford Ranger XLT - 103K
    Jul 2007
    22
    Never mind. My answer only applies to the passenger side of the van....
    Look at your top radiator hose, thermostat housing or the Radiator.
    T&CFan Guest
    That location reminds me of the drain plug on the very bottom of the driver's side of the radiator that was on our previous generation Chryco minivans. Not hard to check if you can crawl under front bumper with a flashlight. As said earlier, might also be failing hose or clamp that may not line up directly over the stain on the deck because the fluid may have tracked along other surfaces before it finally found it's freedom.
    Apr 2007
    San Diego
    5,208
    If you're so inclined you can head to an Autozone or the like and sign out a coolant system pressure tester for a deposite. It will apply constant pressure so you can trace down the leak. If you want to buy one last time I checked I saw them for $30.
  9. The Following 2 Users Say Thank You to RIP For This Useful Post:
    cgar(11-30-2010), dun4now(11-30-2010)
  10. #7
    Jul 2008
    Niles Il.
    10,101
    I agree with using the tester. Or inspect the rad hoses and the metal pipes that wrap around the engine for the heater core supply.
    '69 GTO drop top
  11. #8
    Apr 2009
    Empire State
    3,814
    how much coolant are you loosing? (& when? - only under pressure or while sitting cold)
    check the overflow reservoir and the hose leading to it..
  12. #9
    Mar 2009
    Central OH
    369
    Check the upper radiator hose where it comes from the thermostat housing. It could just be your t-stat housing leaking. As also noted, the radiator drain is on the driver's side. Lastly, I believe the reservoir is also on the driver's side....make sure it's not leaking.
    2012 Chrysler T&C Touring 3.6 - Family Hauler
    2005 Chrysler T&C Touring 3.8 - RETIRED (Traded at 97K miles)
    "Every tyrant in history has known you can't control an armed population. That is why Hitler, Stalin and Mao were strongly against an armed citizenry, while Thomas Jefferson, George Washington and John Adams were for it."
  13. #10
    Aug 2008
    60
    4
    I got a pressure tester and the pressure drops pretty fast. I can also hear a hissing sound while I pump the pressure tester. Sound seems to be coming from the drivers side front near where the drips are showing up. Going under the van and feeling the bottom of the overflow bottle it is wet as are the nearby hoses (some of which are wrapped in mesh). While I can hear the noise and feel the wetness, I'm still unsure exactly where it is coming from.
  1. Transmission fluid leak from drivers side halfshaft
    By chad_webb in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-16-2008, 08:04 PM
  2. small fluid leak under the passenger front side on 2000 T&C AWD Limited
    By bas2000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-06-2008, 04:47 PM
  3. Cold Air on passenger side and warm on drivers side
    By billg13 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-24-2008, 03:09 AM
  4. Disappearing Coolant --> SEVERE Coolant Leak
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-29-2007, 08:52 AM
  5. fluid leak in the inside front passenger side
    By double dee in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-15-2007, 12:16 AM
