2005 Caravan Stalls on Fill up
Results 1 to 8 of 8
Thread: 2005 Caravan Stalls on Fill up
    Nov 2010
    1
    My Van stalls after driving about 1/2 mile after filling up. It starts again and have no other problems until the next fill up
    Jan 2008
    Nova Scotia, Canada
    16,565
    Quote Originally Posted by schunkman View Post
    Be careful not to overfill as that can cause stalling/roughness problems. Evaporative system tends to plug up with raw gas.
    Dec 2003
    Eau Claire, WI
    2,800
    Welcome to the forums- glad to have you here.
    Does the van have any check engine lights? Any codes stored in the computer? (You can check by turning the key to "ON" three times- ON-OFF-ON-OFF-ON- then leave it ON, careful not to start it- just turn it to "ON" and see if any numbers appear in the area where the odometer would normally be.) Also if you're overfilling, as Jeepman mentioned, that can cause evap problems.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
    Apr 2009
    Tampa, FL
    315
    2004 Town & Country Limited
    Magellan 9055 7" GPS
    Uconnect Bluetooth
    Sirius satellite radio
    Backup Camera viewed through GPS
    Painted splash guards, running board & spoiler
    Complete rebuilt front end suspension
    Class 3 Curt Tow Hitch
    Underhood light
    49" LED Tailgate Brake Light Bar
    LED Tail lights & third brake light
    HID Projector Headlights w/ LED running
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    I recall in a previous thread (not sure which, but some while back) this very thing was discussed and a solution was discovered. Yes, it's from topping your tank off and the excess fuel gets sucked into the charcoal canister with the engine starts. This raw fuel goes directly into the engine (intake manifold) from the canister and the engine isn't expecting it, hence it stumbles and quickly dies (you just flooded it). Good news is it will quickly recover, usually by just restarting it. I vaguely recall some sort of fix including a check valve or some thing at the canister, or the canister, itself. Anyway, now you atleast know what the cause is.
    When the pump clicks off, don't overfill ........
    Still Going Strong
    Jul 2008
    Niles Il.
    10,101
    Definitely the check valve. It is odd how the 4th gens are plagued with this issue. I can fill my van until it spews out of the filler and it never stalls.
    '69 GTO drop top
    Jan 2008
    Nova Scotia, Canada
    16,565
    I can overfill mine as well and have noted no problems. Must have a 3rd Generation gas tank.
    Bottom line: Best not to overfill, too much expensive gas on the ground.
    Jan 2006
    Katy, Republic of Texas
    1,105
    My '05 had (has) the same issue.
    I just let the tank fill till the first click and thats it and I have not had an issue since.
    Just a note: If you have five dollars and Chuck Norris has five dollars, Chuck Norris has more than you.
  1. Stalls after gas fill ups.??
    By zurcher in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-08-2014, 01:32 AM
  2. 91 caravan stalls sputters /replaced fuel pump
    By HarryR in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-03-2010, 07:06 PM
  3. 96 Caravan stalls at high and low speeds
    By lites59 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-06-2007, 09:07 AM
Tags for this Thread
