Trouble engaging reverse
Results 1 to 10 of 11
Thread: Trouble engaging reverse
    Sep 2003
    115
    My rebuilt tranny on my 05 GC SXT (which is now out of warranty)
    Now that it has gotten colder, when the car sits( after work) it wil not go into reverse. If I rev the engine, let it return to idle it goes into R just fine and works like new. It shifts fine- works great
    Fluid only has 14k on it, level is perfect.
    Any ideas?
    The tranny shop that did the rebuild is hopless- going back is not an option
    Mar 2010
    Bethlehem, PA
    303
    time for a new filter, I think the filter is clogged
    Dec 2007
    Missouri
    49
    7
    Are you sure they used ATF-4 ? Why was the trans rebuilt? A catastrophic failure could leave particles and chunks of things floating around. Maybe something is hung in the valve body. But I'd start with the fluid and a filter.
    01 G.C. 98000 Miles. 3.3litre
    Jun 2009
    Jefferson City, TN
    3,051
    If the tranny shop didn't flush the fluid lines and cooler, you could be in for more costly transmission issues. Hopefully that's not the issue...
    Jeff
    Current:
    Previous minivans:
    Sep 2003
    115
    they claimed they used atf 4+.- don't trust them for anything but they do a huge volume. They have a good rep- don't know how..
    At any rate- the solenoid pack is now leaking at the gasket. For $100 I will install a new solenoid pack since I need to replace the gasket any way. Any difference btwn Borg Warner & Dorman? I can't find any info on Dorman.
    Jul 2008
    Niles Il.
    10,101
    I think the solenoid pack was not replaced. That would be my first suspicion if the fluid looked good.
    '69 GTO drop top
    Sep 2003
    115
    yes- fluid looks good and is only 14k old. Ordered a BW solenoid- $99 delivered to my door. I'll give it a try. I will take the old one apart- see if any screens are clogged.
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by patrick30 View Post
    Dorman is Borg-Warner, they all are. Mine said Dorman on the box, Borg on the paperwork.
    PS..hope it helps. A new pack smoothed out a rough shift from 1st to second I had. Do change the fluid and filter with ATF+4, also.
    Sep 2003
    115
    swapped out the solenoid tonight. Repair shop used a felt gasket & not sure it was the right one- pattern did not match the solenoid @#$%-!!!!
    I had to remove the cooling lines in order to remove the speed sensor so I could get a good shot at the middle bolt- was on good.
    Nov 2008
    DeSoto County, MS
    2,926
    The new solenoid should have come with the proper gasket. Did it not?
  1. 1997 T&C Fans not engaging!!! HELP PLZ!! LOL
    By tahopp in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-03-2010, 06:15 PM
  2. A/C clutch not engaging
    By psychic_mechanic in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 07-16-2010, 11:14 PM
  3. A/C clutch engaging in freezing weather?
    By FrogNoggin in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-05-2009, 11:13 PM
  4. Tranny not engaging after sitting for a year!
    By zpolovin in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-20-2009, 06:41 PM
  5. 99 ply,outh grand voyager tranny not engaging
    By Rob in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-27-2008, 08:57 PM
