In the last few days, I have noticed that after sitting overnight, there is a rather large cloud of blue smoke (exhaust) whenever I start it up ..Its a 4.0 with 5000 km on it...I don't think its normal..Anyone with similar issues?
Or your engine is more likely munching oil through the valve stem seals. It only happens when sitting for long periods because during that time, the oil on the valve stems has the chance to seep all the way down into the intake ports and then the combustion chamber. Eventually it will probably smoke upon deceleration or when taking off from a stop.
I would say that isn't normal at all for a new engine. Damn if it does that now imagine in another 20000. Our 4.0 doesn't smoke at all except for when we seafoamed it and it was quite a sight
Keep us posted!
24,000kms
The weather is getting cooler, are you just seeing normal exhaust vapor upon start-up? If not, like other's have said take it to the dealer, leave it over night, and let them see it.
Thanks to everyone for their thoughts and ideas..The smoke was obviously blue, meaning oil and there are only 1000 km on it since an oil change. There is no usage shown (there really aren't enough km's to tell)...Stay tuned...S
Take it back to the dealer and raise cain. Leave it overnight and ask them to wait until you get there in the morning to see it. This is not normal, and if it is an oil problem, they could blame you if it goes bad.
Sounds like oil getting into the engine overnight through leaky valve seals. Yet, you are seeing no oil consumption. Better get the Dealer to check it out.
I would look into the PCV as possibly a reason, when changing the oil you put alot of oil up into the top of the valve cover, if any gets onto and sucked into the egr you can get this smoke. I would suggest pulling it off cleaning it out and checking if goes away before spending money on changing perfectly good oil you have in there.
Also I would like to point out to the OP that a few of the larger motors the chrysler/dodge put into the trucks and libertys had issues with oil foaming. I ve not noticed any of the signs on our van but I wouldn't
count that out as a reason for "oil" to get into the PCV so easily.
Related Threads
572K posts
80.4K members
Since 2003
