Chirping Noise From Belt Area
Results 1 to 9 of 9
Thread: Chirping Noise From Belt Area
    Mar 2010
    17
    2004 Town and Country Touring
    Hello everyone. A few weeks ago i had my mechanic change my serpentine belt. it was making some noise when the engine was damp or cold. He told me he wasn't able to make it tighter and that the belt seemed to be just slightly too long at this point. He replaced it. All was well.
    This past weekend I noticed some chirping coming from the engine. When I looked closer, i can tell it is coming from about the same area as before. But, this time it is chirping any time I accelerate. I called him this morning again and he thinks maybe there is a bad bearing in the pully system. It seems to be getting louder as i continue to drive. Seems to be basically quiet when just idling.
    Would you concur? Anything else I should consider?
    Jul 2008
    Niles Il.
    10,101
    The belt tensioner could also be bad. If the belt doesn't get tight enough, it will chirp or squeal under acceleration.
    '69 GTO drop top
    Mar 2010
    17
    Thanks. Would you expect that to be a pricey repair?
    Jan 2005
    Fayetteville, NC
    9,436
    They're not all that expensive. My 2007 has been through 3 of them, all under warranty. Also look at the belt itself. The Mopar belt has a textured top surface that stays quiet when running on a smooth pulley. I tried a Napa belt on it, but the slick top surface would chirp on the smooth pulleys. Going back to the Mopar belt quieted it back down. Whenever I do have to replace the belt, I'll probably buy a Mopar one.
    Nov 2009
    21
    Could be the tensioner as was mentioned. Might check your water pump, too. You'll have to be under the vehicle and look for dampness around the shaft of the water pump.
    And watch the vibration dampener (crankshaft pulley) while the engine is running to make sure it's not wobbling. I just replaced the pulley and water pump on my '03 because of the squeaking.
    _____________________________________
    2003 Chrysler Town & Country 3.3 Flex Fuel
    Jun 2009
    Western Mass
    70
    4
    I had a squeak on cold damp start-ups on my 03 and when I checked the belt & pulleys I noticed that there was a little play in the idler pulley which is the easiest one to see & check. I replaced it and so far no squeaks. I managed to change it without removing the belt by putting a wrench on the tensioner from below and using a floor jack to relieve the belt tension just enough to get the idler off. That saves the hassle of removing and replacing the belt.
    Moby Van--2003 SWB 3.3
    Red--1993 Trans Am
    Toy--1966 Corvette
  9. The Following User Says Thank You to micondie For This Useful Post:
    dun4now(12-02-2010)
  10. #7
    May 2007
    27
    2
    Had a similar problem, I had to replace the tensioner and the alternator. All the noises went away with the repair.
    Initially I was concerned because the noise seemed to diminish when I turned off the AC so I though it might be the compressor, but the main culprit apparently was the alternator.
  11. #8
    Jul 2007
    Pittsburgh, PA (West)
    22
    I had the same problem - fixed it today. - Replaced the tensioner and Idler pulley. Took less than 1 hour. Fixed the squeal.
  12. #9
    Feb 2017
    1
    2005 Chrysler Town N Country Stow and Go
    I have that in my 2005 Chrysler town and country stow n go and it wont quit what could be the problem
  1. Rattle Around Belt Area
    By morpheus101010 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-28-2010, 05:51 PM
  2. Rattling noise from s-belt area
    By Haggy in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-12-2008, 10:04 AM
  3. front end chirping,grinding noise
    By donk in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-21-2008, 04:34 PM
  4. ringing sound in drive belt area
    By aggiejet in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-15-2007, 07:17 PM
