Starter/Solenoid/Relay -- How do you know which?
Results 1 to 5 of 5
Thread: Starter/Solenoid/Relay -- How do you know which?
    Oct 2007
    66
    14
    My 2000 Grand Voyager starter isn't turning over. Thought it was the battery, but a new battery proved me wrong. The Starter Relay is easy enough to check. But how do you determine whether it is the Starter itself, or the Starter Solenoid?
    Let me know,
    Thanks in advance,
    Bruce
    2000 Chrysler Grand Voyager
    3.3 v6 , 4 speed auto
    trailer tow prep
    Silver
    147,000 miles
    Oct 2003
    321
  4. The Following User Says Thank You to Vision67 For This Useful Post:
    Armadillo(10-03-2010)
  5. #3
    Jul 2008
    Niles Il.
    10,101
    In our vans with the nippon denso starter, it is usually the solenoid. But replacing the whole thing is better because the motors wear too.
    '69 GTO drop top
  6. The Following User Says Thank You to andyg For This Useful Post:
  7. Remove Advertisements
  8. #4
    Oct 2007
    66
    14
    Thanks all. Look like I'm replacing the Starter. I've seen blogs stating not to use a remanufactured, but my van is 10 years old, and using a new starter seems like gilding a lilly. Rockauto.com has Nippon Denso, AC Delco, Remy, Bosch and Beck/Arnley. Nippon Denso seems to be very popular.
    trailer tow prep
    Silver
    147,000 miles
  9. #5
    Jul 2008
    Niles Il.
    10,101
    Nippon denso is the original supplier/design of the starter. I used a bosch on mine and it is also good. Any of the choices you listed would be fine.
    '69 GTO drop top
  1. Is it the solenoid pack?
    By hawkeye52 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-13-2011, 07:14 PM
  2. EGR Solenoid Problem
    By hypervish in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-15-2009, 04:40 PM
  3. starter relay switch 92 Dodge Caravan
    By sugarbexar in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-14-2009, 10:44 PM
  4. Leaking solenoid pak
    By j charles in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-21-2008, 12:35 PM
