How do I set my clock?
Results 1 to 10 of 12
Thread: How do I set my clock?
    May 2010
    Grand Junction, Colorado
    67
    I haven't referred to the SERVICE manual yet to see if it says anything, but the OWNER'S manual is supremely unhelpful when it comes to using the stereo ("Please refer to the Chrysler Car Audio Manual" or somesuch).
    Most everything on the stereo is pretty self-explanatory, but I can't figure out how to set the clock. I've played with just about every combination of buttons that I can try, but no luck. Short of unhooking the battery at noon, can anyone tell me how to do this?
    "Ahab knew, baby...I lust." -- Vet-san
    1990 Dodge Caravan SE, 3.0L 3-speed, 130,000 miles
    1995 Plymouth Neon, 2.0L SOHC base model, 134,000 miles
    2004 Honda Element EX, 70,000 miles
    Nov 2008
    DeSoto County, MS
    2,926
    There are usually 2 tiny, recessed buttons labeled M and H, and they can be hard to see. They are sized to be pressed with a pen head.
    On this one, it's to the right of the tape deck. Yours is probably similar, though I'm not entirely familiar with the radio line up in the 1st gen's.
    May 2010
    67
    I'll check again, but I don't think I have those.
  5. #4
    Feb 2008
    Central British Columbia
    796
    Press the SET button then it goes into P1 mode, press again for P2 mode,( hours and minutes), then turn station dial.
    this is off the top of my head, i'll have to go check my older van.
    Radio must be turned ON, cant set time in the OFF position.
    2003 Caravan SXT 3.3L / 1997 Grand Voyager SE 3.0L / 1991 Plymouth Voyager 3.0L / 1989 Plymouth Voyager 2.5L / 1988 Caravan 3.0L / 1984 Caravan 5 Speed Stick
  6. The Following 2 Users Say Thank You to hwystar For This Useful Post:
    arex(09-28-2010), sideburns2009(09-28-2010)
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by hwystar View Post
    That may be correct. We've never owned a 1st gen van, hence my lack of knowledge on their radios, but I believe this is how you set the clock in my mom's old '91 Plymouth Acclaim. That procedure rang a bell, anyway.
  8. The Following User Says Thank You to sideburns2009 For This Useful Post:
    hwystar(09-30-2010)
  9. #6
    May 2010
    67
    This is the stereo I have. I'll try the procedure after dinner. Thanks!
  10. #7
    Dec 2003
    Eau Claire, WI
    2,799
    Hwystar's procedure should work like a charm. I seem to remember that procedure from my '92 before I replaced the head unit with one that has an auxiliary input for my iPod.
    Kevin Peterson
    Senior Global Moderator
    Chrysler Minivan Fan Club Forums
    "In a completely rational society, the best of us would be teachers and the rest of us would have to settle for something else." -- Lee Iacocca
  11. The Following User Says Thank You to jazztrumpet216 For This Useful Post:
    hwystar(09-30-2010)
  12. #8
    May 2009
    South Dakota
    31
    1
    From the Chrysler Sound System manual:
    Clock setting procedure - Radios WITHOUT GRAPHIC EQUALIZER
    To start the procedure, the radio display must be showing the time. If the radio frequency is being displayed, press the SEL button to activate the time display.
    1. Press the SET button and "P" will be displayed.
    2. Press the SEL button and the hour will be displayed.
    3. Rotate the tuning knob to change the hour setting.
    4. Press the SEL button again to display minutes.
    5. Rotate the tuning knob to change the minute setting.
    6. Press the SEL button once again to complete the procedure.
    Clock setting procedure - Radios WITH GRAPHIC EQUALIZER
    1. Using the point of a ballpoint pen or similar object, press either the hour (H) or minute (M) buttons on the radio. The display will show TIME.
    2. Press the H button to set hours or the M button to set minutes. The time setting will increase each time you press a button.
    3. Press any other button to exit from the clock setting mode.
  13. The Following User Says Thank You to BenHertz For This Useful Post:
    arex(10-04-2010)
  14. #9
    May 2010
    67
    Quote Originally Posted by BenHertz View Post
    Ah ha! THIS correlates with what I'm seeing...I couldn't get it to work with the other procedure, but this looks like it might. I'll try it when I get home from work tonight.
  15. #10
    May 2010
    67
    It works! I wish all car stereos were this easy.
  1. Clock Spring !
    By seaspice in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-04-2010, 03:24 PM
  2. clock spring
    By cb88 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-27-2009, 09:47 PM
  3. setting my clock
    By snowylady_99 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-07-2008, 11:59 PM
  4. clock spring
    By paully in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-11-2008, 08:52 AM
  5. 96 T&C clock setting
    By bantylady in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-28-2007, 11:32 PM
