Oil filter by-pass valve position - threaded or dome?
Results 1 to 10 of 11
Thread: Oil filter by-pass valve position - threaded or dome?
    Jan 2008
    Saint Paul, Minnesota
    304
    Question Oil filter by-pass valve position - threaded or dome?
    The oil filter on my 3.3l Chrysler is vertically mounted. Does it make any difference whether the oil filter's by-pass valve is located in the threaded base end or the dome end? I am wondering which would be best (if either) for cold weather starting to ensure start-up oil to the engine
    2003 Chrysler Voyager LX 3.3l ( SILVER )
    Allison Acoustics
    Most folks are about as happy as they make up their mind to be - Abraham Lincoln
    Jul 2008
    Niles Il.
    10,101
    Doesn't matter. Just run a good filter and everything will be fine.
    '69 GTO drop top
    Oct 2008
    2,469
    43
    I would agree, once you burp the air after inserting a new filter, It should not run back regardless. With the advance of newer oils and additives, it is very likely not a big deal anyway, since most modern oils have the tenacity to stay on the engine surfaces until the pressure gets up again during a start up, but it certainly has to be better if it gets oil even quicker.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jan 2008
    Nova Scotia, Canada
    16,448
    I prefer the bypass valve at the base, like on the Mopar filters. Having said that, the unfiltered oil bypassing at the cap end probably makes no difference. In a bypass situation, it's unfiltered oil anyway. As to the filter being vertical, I wouldn't worry about that either.
    How often does a bypass situation exist, that's the question. Probably more often than one thinks.
    Jan 2005
    Fayetteville, NC
    9,436
    I prefer it at the threaded end. Most OEM-spec filters (like the Mopar and Motorcraft filters) specifically call for threaded-end bypass valves. The generic filter numbers use a generic dome-end bypass. As Jeepman said, bypass happens more than you probably think it does, and with a threaded-end bypass, the sediment that will naturally build up in the dome end of a vertical-mounted filter doesn't get disturbed.
    Given a choice, go with the threaded-end bypass.
    Jan 2008
    Nova Scotia, Canada
    16,448
    The Fram Tough Guard 8A has a screen over the bypass valve (located at the cap end). Here's a picture of it (on the right side in the picture).
    Some people use magnets on their filters to attract any metal pieces or go for the Force Field pre-filter magnet shown here. That sounds useful.
    Then again, there's the efficiency of your filter as purchased. The Fram TG8A above has a dirt trapping efficiency of 99%. Apparently some filters have efficiencies as low as 80%. If they don't tell you their % efficiency, in their technical information, may as well assume a lower efficiency.
    For information purposes only, I have included a picture of the bases of a Mopar, Wix Premium and Fram TG8A filter, showing the color of the anti-drainback valve (a different animal than the bypass valve) materiel, which can be seen through the smaller hole around the center hole. The oil from the oil pump passes through these smaller holes, enters the filter chamber, goes through the filter media, then out the center hole, then up to the engine. The dirt in the oil is "trapped" (not just stopped) by the filter media. The orange anti-drainback material is silicone, a superior materiel to the black nitrile in the Mopar.
    Jul 2008
    Bucks County, PA
    646
    41
    Which manufacturer puts the bypass valve on the threaded end? I thought that's just where the anti-drainback valve would be.
    Bill
    2001 Dodge Grand Caravan Sport, 3.3 flex-fuel V6
    Jan 2008
    Nova Scotia, Canada
    16,448
    Quote Originally Posted by Dodgeboy77 View Post
    Bill
    The Mopar filters (Wix in Canada, Purolator in the US) have the bypass valve at the base (where the holes are and just in back of the anti-drainback valve). The Wix premium has the bypass valve at the base. Take a look here.
    I attached a picture of a Wix premium filter that I cut apart.
    I believe the various Manufacturers have filters with the bypass valve at either end, depending on which level of filter you buy, or what the vehicle manufacturer specifies (such as Mopar).
    Note: Anyone interested in the Fram Extended Guard, take a look here, it's impressive. It's no low end filter for sure. Holds 30 grams of dirt at 97% efficiency versus the Pure 1 at 12 grams and 99.9%.
    Jan 2008
    304
    Question Ice in winter?
    I have heard about the oil picking up crud if the bypass valve is in the dome position and opened, but I came across this one in browsing the internet. In very cold winters, like we have in Minnesota, moisture can collect at the bottom of the oil filter and freeze. This ice will then inhibit the operation of the dome valve on cold startup. Any opinions on this? It could be another reason to use a threaded bypass filter.
    Allison Acoustics
    Jul 2008
    Niles Il.
    10,101
    Your oil has emulsifiers in it to prevent oil from separating. If you have that much water int he oil, you have bigger problems as any drive over 10 miles will heat the oil enough to boil out any water. That should be a non issue.
    '69 GTO drop top
  1. PCV valve replacement - trouble with valve cover insert
    By bnut2000 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2014, 08:35 AM
  2. Dome Light does not work
    By Jos Sauren in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-11-2009, 08:56 AM
  3. high pressure port valve=charger valve???
    By mewant2b in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-24-2008, 05:41 PM
  4. Dome light issue
    By ddsebast in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 09-11-2008, 10:45 PM
  5. PCV Valve Fuel Filter Q
    By jayunit1689 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-30-2006, 11:03 PM
