Radiator fan not working after Replacing Relay
Results 1 to 10 of 14
Thread: Radiator fan not working after Replacing Relay
    May 2009
    35
    Almost overheated one day cause fan wasnt working. Checked continuity on 40AMP fuse with my DVOM and it checks out good. Replaced relay with this: http://cgi.ebay.com/ebaymotors/ws/eB...SA%3AUS%3A1123
    Fan still not working after turning on A/C. I jumped the Green and Gray wire at the relay harness and the passenger fan came on but not the driver side one. What am I missing?
    Any help appreciated!
    1997 Caravan Base 3.0L, 2000 Grand Caravan SE, 1998 Ram Sport Edition
    Jul 2008
    Niles Il.
    10,101
    I wonder if your fans are bad. The fans are wired together so if one comes on (given enough power is available?) the other will be right with it.
    '69 GTO drop top
    May 2009
    35
    I was thinking the same thing. If one is on, the other should run as well. I havent driven yet to the point where the PCM commands the fans on since replacing the relay. Probably should've done that first.
    Apr 2007
    San Diego
    5,240
    Don't delay. If that fan is bound up it could draw to much current through the circuit and fry the relay. Spin it by hand. It should turn freely.
    Feb 2008
    Central British Columbia
    801
    Both of my gen 3 fans are working properly and the fan on the left side turns ON with the coolant sensor and the fan on the right side turns ON with the A/C
    I don't think they're both wired together, or are mine the only ones that do this?
    2003 Caravan SXT 3.3L / 1997 Grand Voyager SE 3.0L / 1991 Plymouth Voyager 3.0L / 1989 Plymouth Voyager 2.5L / 1988 Caravan 3.0L / 1984 Caravan 5 Speed Stick
    May 2009
    35
    Quote Originally Posted by RIP View Post
    Great. Finally drove it today and I just got a P0118 (Coolant Temp Circuit High Input)and P1491 DTC. Im guessing the new relay got toasted. Fans didnt work.
    Also, I checked the feedback for the ebay seller I bought from and it looks like a number of buyers for that relay returned them back to the seller.
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by hwystar View Post
    Must be different designs. I have good experience with the fans as I retrofitted a spare set of 3rd gen fans onto my GTO in my sig. The fans were wired together and come on at the same time. Also when watching my van, both come on at the same time. There were slight design changes between the 96-97 and 98-00 vans.
    '69 GTO drop top
    Feb 2008
    801
    Good info, thanks Andy, I didn't know that.
    Jul 2005
    NJ
    1,571
    6
    I believe the fan assembly is the same part for all years, with motors connected in parallel and a single plug.
    Maybe someone had done some re-wiring.
    May 2009
    35
    Theres a plug harness going to each fan on my 97.
    Anyone ever tried replacing the motor itself? Found this: http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
  1. radiator fan relay
    By p4ca in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-13-2010, 10:11 AM
  2. 1998 T&C Radiator Fan relay
    By Sow Lancelot in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-20-2009, 08:40 AM
  3. '98 T&C radiator fan relay question
    By bastrop98T&C in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-05-2009, 06:12 PM
  4. Radiator Fan Relay on Ebay
    By phildg2000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-02-2008, 10:45 PM
  5. Code 35, Fan relay not working
    By hemicar in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-01-2007, 09:27 PM
