Hood Rust...Any way to fix?
Results 1 to 10 of 15
Thread: Hood Rust...Any way to fix?
    Sep 2006
    517
    2
    This is the hood on my '05, which is upsetting. I had some rust on the seam of the rear deck lid that I had my local body shop sand out, treat, and reseal. It's been good ever since. I'm thinking that for the hood, it's too late to fix and probably cheaper to replace. Thoughts? My '01 has an aftermarket hood, which seems to be less rust prone than the OEM. If I do need to replace, I'll probably go with aftermarket.
    2014 Chrysler Town & Country 30th Anniversary Edition
    2014 Acura MDX
    1996 Mustang Cobra
    1995 Lincoln Mark VIII
    Jul 2008
    Niles Il.
    10,101
    When rust is in a folded seam, replace it. It will never go away, and will come back quickly if repaired.
    '69 GTO drop top
    Mar 2007
    Holland, MI
    1,613
    7
    Looks like mine. It got a yearly wire-wheel, coating of oil-based metal paint and a bug deflector. I kept it in check under the deflector and it was never much of a problem.....
    2010 Honda Oddy LX - 9k miles - Land Barge
    2008 Honda Fit Sport - 31k miles - What a riot!
    1996 Toyota Land Cruiser - 292k miles - Tank
    Gone - 2001 DGC Sport 3.3L 169K
    Aug 2010
    mifflinburg, pa
    18
    mine is doing the same thing on the back side and some on the front. also has spot on roof. getting it all done for $300 from a friend that works in a chrysler body shop and has had his own body shop ever since i was a baby. (was his dads shop from the '40s i think)
    05 town and country
    00 ford taurus wagon
    86 shelby glhs #68
    77 pontiac astre
    Jul 2008
    Cincinnati
    323
    With all the rust mine has had amazingly I have not had any surface rust on the hood. I treated the seams on the back lift gate with some rustoleum rust converter and that worked really well. I have not painted over it yet (and I hit it with the rust converter every now and then) and it seems to have done a good job so far (for $6).
    I like the idea of the bug deflector instead of getting a new hood.
    2005 T&C Signature Series, 64,xxx miles
    Lots of rust, leaking steering rack, bad rear AC condenser coil, rusted (and replaced) rear brake line. Looking forward to the next failure/defect that this Chrysler will bring into our lives.
    Mar 2007
    137
    5
    Mine is all the way through. Front tip of passenger fender too. How much are those after market panels?
    2002 Town & Country Limited 150K
    2007 Toyota Avalon
    2002 Honda Accord
    Oct 2003
    Niagara Ontario
    825
    Spray some "rust check" spray into the seam from behind. It will slow the rust down or stop it.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
    Dec 2009
    MA
    284
    5
    I'd just slap a bug deflector on and hide it. that's what I did with my '02 when i bought it 3 years ago and it never managed to rust past the bug deflector to where it was visible. a whole lot cheaper plus i think it dresses it up a little bit and helps with the bugs
    2011 Grand Caravan, 3.6, 144k miles
    1993 Chrysler Concorde, 3.3 150k miles
    1999 GMC Suburban k1500, 5.7, 179k miles
    2006 Pt Cruiser 2.4, 129k
    1987 Monte Carlo SS Aerocoupe 5.0, 76k
    1997 Firebird Convertible, 3.8, 53k
    1960 Corvair Sedan, 2.3, 87k
    Past Caravans:
    2005 Grand Caravan SXT, 3.8 247k miles, Sold
    2002 Grand Caravan SE, 3.3, 166k miles, Sold
    Feb 2007
    Southwest Ohio
    353
    BOB96:
    WOW...... that is some hood rust for a five year old vehicle.
    Our 2005 has some rust starting along the inner part of the both rear wheel wells.
    So far, nothing else has appeared. What is your build date? Ours was 08/31/04 so it is now 6 years old.
    Don
    2011 Mineral Gray Hyundai Santa Fe GLS AWD 3.5L V6
    2014 Billet Silver Charger R/T AWD
    04 Flame Red 5.7L Durango SLT
    Nov 2009
    Southwestern Michigan
    55
    I had hood rust starting in the seams within months of driving my 2003 new off the lot. Dealer body shop touched it up with paint no charge but Chrysler refused to replace hood since it was not a perforation. Problem could have been prevented if seam sealer & better prep used @ the factory before painting. Like was said previously, once rust starts in a body panel seam, the only permanent fix is to replace the entire panel. My hood rust is now far advanced with exterior paint bubbles. Earlier than expected seam rust is a problem on these vans and other models of Dodge/Chryslers of this era. I see it often in my travels. The seam rust is probably the most disappointing part of my van ownership experience which has been very positive overall.
  1. 2001 T&C hood rattle noise at hood hinge. TSB?
    By Dave Maher in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-29-2010, 10:00 PM
  2. Hood and Deck Lid Rust Warranty Replacement
    By zulater69 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-05-2009, 08:18 PM
  3. Hood Rust - what can I do to slow/prevent the spread?
    By Mahones in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-10-2009, 11:51 PM
  4. Hood Rust
    By 2002CaravanSE in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-06-2009, 07:29 PM
  5. Hood Release Cable Broken.. How can I open Hood
    By d2benz in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-04-2008, 01:57 PM
